Check out my new possible cam specs
Old Feb 27, 2008 | 06:33 PM
tarinitup's Avatar
9 Second Truck Club
Default Check out my new possible cam specs
Cam recommendation: (2000 Extended cab Sierra with 402 block, Patriot stage 3 heads, LS6 intake and 78mm TB, 4L80 trans with 3200 stall, 4.10 gears, 1 ¾” long tube headers, no cats, 6400 rpm shift point, 6700 rpm rev limiter, 250 shot N2O)
238/250 .619”/.630” 112LSA +3 advance (with 1.8 ratio rockers)
Comp XE/XE lobes
3652R/3658R HR112LSA +3 advance (109 installed intake centerline)
Static/Dynamic Compression with new cam: 10.50:1, 7.83:1
Recommended springs: Patriot Gold duals with Ti retainers.
Recommended pushrods: 7.400”.
Let me know what you guys think. Patrick G. said it would still have decent street manners and would really wake up the truck.
Old Feb 27, 2008 | 06:36 PM
silver-mod-o's Avatar
Hunt&Fisherator
thats a good size split... I would change up the LSA a bit but other than that I'd run it... seems like it would be a good mannered cam for the boottle...
Old Feb 27, 2008 | 06:40 PM
tarinitup's Avatar
9 Second Truck Club
This is what he wrote,
On motor, you ideal cam would have been 238/242 .619/.626 110LSA +1 advance. But with a 200-250 shot, we'll want to open up the exhaust valve earlier while keeping the IVO, IVC, EVC and overlap the same as the NA cam. This is how we came up with the 238/250 .619/.630" 112LSA +3 cam.
Old Feb 27, 2008 | 07:32 PM
chris04's Avatar
my buddy has almost the same cam specs in his 408, sounds nasty and has plenty of power as well, i think this motor will love it,especially with the juice,sounds like a good cam man! be sure to let us now how you like it when you get it in.
Old Feb 28, 2008 | 05:02 PM
tarinitup's Avatar
9 Second Truck Club
Bit the bullet and ordered it. Hopefully it will get here quick so I can get it tuned by Nelson on my Houston trip on the 28th of march. If not then a mail order will have to do.
Old Feb 28, 2008 | 05:11 PM
joshua022's Avatar
How much milling is done on your heads if any?? With that much lift will you run into any PTV clearance problems?? .655/.667 (with the 1.8s)
Old Feb 28, 2008 | 06:58 PM
tarinitup's Avatar
9 Second Truck Club
Heads are 64 cc patriots, and the lift provided with cam specs incudes the 1.8 rockers so max cam lift will be 630. I am worried about daily driving with the new cam but I was assured that it would still be good. If all goes well the new cam, ls6 intake, and 250 shot will net me a 10 sec pass next winter.
Old Feb 28, 2008 | 07:30 PM
joshua022's Avatar
Oh ok gotcha, i thought the specs were for stock rockers.
Its nice to hear that someone has such a built truck and enjoys it enough to drive it everyday no matter how high gas prices get.
Good luck with your cam.
Old Feb 28, 2008 | 10:37 PM
Dark Halo's Avatar
that is really making me want to go bigger now
Old Mar 2, 2008 | 05:28 PM
Jessica's Avatar
Restricted User
20° of overlap honey? on a DD
