Check my math
Old Jan 17, 2008 | 04:21 PM
I wasn't sure if it was 2cc or 7cc. I read 2cc somewhere.
joshua022's Avatar
Originally Posted by tdrumm
Where did you get the 2cc piston dish number? Because with 62cc chambers in those heads and stock pistons you should still be around 9.4-9.5 Static compression ratio, which would put your DCR in the mid to high 7's (just estimating).
I agree ^^^^
really nothing in your set-up has changed from the stock CR, because the heads haven't been milled and your using a stock head gasket.
Old Jan 17, 2008 | 04:26 PM
Zick's Avatar
Well if that's the case, your DCR is pretty low. Not going to be peppy with those numbers.
Old Jan 17, 2008 | 04:27 PM
SCR= 9.63 DCR=7.59 with 7cc dish. So y'all are right.
So should I get the heads milled and go with a .040 gasket to up the CR?
A SCR 10.5 / DCR 8.25 would be nice.
It runs decent, but I think it has a lot more in it.
Old Jan 17, 2008 | 04:33 PM
Right now I am thinking 347 after punching some numbers.
This is the exact reason why I tell people to research before they do things. I was planning on a 347 eventually.
Old Jan 18, 2008 | 07:04 AM
tdrumm's Avatar
I bet if you took a poll here, you would find a lot of cammed and even heads/cam trucks (including mine, 7.93:1 DCR) are below 8:1 DCR. There is only so much you can do to raise compression on a stock shortblock with dished pistons.
Old Jan 18, 2008 | 09:32 AM
Zick's Avatar
Your probably right, I tend to worry about DCR too much.
Old Jan 18, 2008 | 09:46 AM
TXsilverado's Avatar
if your not planning a supercharger or turbo shoot for 8.7 dcr. everyone on tech agrees that thats the limit for 93 octane and mine is loving it.
Old Jan 18, 2008 | 11:57 AM
Slowhawk's Avatar
LS1Tech Sponsor
That would be a horrible power range for a 5.3L.Even in a 5.7 it wouldn't be very good in a truck unless you have 6.xx gears.If you want a fast truck having HP peak at 5500-6000rpm is your best bet. Also don't kill yourself with DCR.It was a hot subject awhile ago but higher DCR NEVER means more power.
Also,the gas in the NE sucks.Add that to a heavy truck and you'll find out quick that the timing has to be lowered a bit which losses power.
