Can someone go over my build?
I'm building a 370 out of an iron LQ4 motor with un milled ported 243's, i will be using the stock crank but i will be going with Eagle forged H beams and forged Mahle pistons with valve reliefs..i wanna know if i'm getting the right Static compression ratio
these are the ones i bought got a deal ($960.00) Tax Exempt through AutoZone
Eagle Specialty Products CRS6125O3D - Eagle ESP H-Beam Connecting Rods - Overview - SummitRacing.com
Mahle LS1314030F04 - Mahle PowerPak Piston and Ring Kits - Overview - SummitRacing.com
^those are the parts i have in my possession, i just got my Tick Stage 2 street heat cam in the mail today as well and it looks killer
, (Thanks for the help martin)
here is what i came up with by using the Excel spreadsheet
Can anyone double check that i got my input numbers correct? 11.x:1 compression sounds nice if i can do it (i will be using stock mls gaskets) and im pretty sure the parts man told me the reliefs in the pistons are 4cc cuts
, (Thanks for the help martin)here is what i came up with by using the Excel spreadsheet
Something seems awry here. An LS2 with the factory flat tops ( no reliefs) is only 10.9:1 static with 243/799 casting heads un-milled. I don't know how far in the hole GM's pistons are off hand on one of them.
Those pistons from what I am seeing have a 4 cc dish to them... not a dome. So that number needs to be a negative and not a positive. From TR's site:
-4cc valve relief ;
So you should change that in the calculation.
Otherwise with the pistons 10 thou out of the hole and a 51 thou gasket that does net a 41 thou quench.
The piston dish is the only thing I see wrong. Should be more like 11.5:1 after that change I would think.
-4cc valve relief ;
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
