can some body tell me what is going on?
Old Dec 27, 2006 | 07:34 PM
TG02Z71's Avatar
Rust can act as an abrasive agent between moving parts. If you look at the back of sandpaper you will see things like "dioxide" and "oxide" printed on them, technical terms for rust. Not saying this is what happened to yours but it can lead to premature failure if there is enough of it in there.
Old Dec 27, 2006 | 10:08 PM
TURBO8's Avatar
Yeah, I think I will just let it blow. I can get a lq9 cheap, but I cant run as much boost because of the compression. I dont know maybe I will just get the lq9. What is the bigest gasket I could use to lower the compression from 10:1. Will the bigger gasket be prone to gasket failure? How low could I go?
Old Dec 27, 2006 | 10:14 PM
TurboGibbs's Avatar
Look at the Titan ICS (SCE). I'm thinking you can get a prety thick gasket. I wouldn't worry about it. Just run the 5.3 but with the thoughts of getting ready to build your next engine before it blows.
Old Dec 27, 2006 | 10:35 PM
TURBO8's Avatar
Yeah, I am most likely going to just run it like that. If it lasted for 7k making the power that it has made so far, I think it will be ok for awhile.
Old Jan 6, 2007 | 05:07 AM
jblack6527's Avatar
If anything, I would just take a little scotch brite and smooth the walls up a little.
calsdad
Jun 14, 2023 11:07 PM
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 06:27 AM
