cam vs shift points
ok so im wondering what cam specs all of you have and what size motor you have and what rpm you are shifting at....please tell me of your set up
204/218 .551 115.5
5.3
6200
204/218 .551 115.5
5.3
6200
Erik, one thing to keep in mind is some people are shifting higher to keep the truck out of the next gear before the traps. IE, in my N/A setup I was hitting peak HP at 6000 RPM but I was shifting at 6400+ to keep my truck in 2nd gear through the 1/4mile because if I droppped to 3rd gear right before the traps it killed my ET. If I short shifted it and let it go into 3rd earlier it was just as bad. The 60E gear spacing sucks
Seems no matter which cam I see dynod in a stock manifold 5.3L peak power is at 5900-6100rpm.
I'll be doing some testing on this with my blown combo and the 80E because as of right now I trap 104mph and am about 6200rpm in 2nd gear crossing the traps but once I pick up some more power and start hitting 108mph traps I may be asking a bit much for 2nd gear lol.
Good topic Soon2bespooled
good info F8L, i wonder how much peak power or usable rpm range would be change with an LS1/6 intake manifold. i have been bookmarking fuel rails and intakes for a while now on ebay and am considering building up the parts including LS1 water pump but that will be another thread for another day
before you start looking at swapping intakes.
the same intake is on the 6.0 that is sitting on your 5.3
with the valves on the 5.3 heads being 1.89 and the valves on the 6.0 being 2.00.
i do think that the numbers on flow through the intake is different.
before swapping them out have you maxed it out yet.
that LS6 cam your running was used with a set of LS6 heads.
not the 5.3 heads you have now.
so what do you think i should do to max out my performance before the intake? are you recommending doing something with the rockers? i have stock heads now ill eventually get them ported and valve job and allthat or stage 2ed
