Cam Swap Suggestions
Old Nov 2, 2019 | 02:47 PM
madmann26's Avatar
Originally Posted by RedXray
Dual springs are a lot heavier than beehives even with the titanium retainers. I've been looking at the PSI 1511ML beehives. I've read there hasn't been any reports of these .625 springs failing but they're $240 a set which is ten dollars more than the BTR .660 springs and a $100 more than the PAC 1219 .625's
The ASA has risen to the top of my list.
On the other truck forum another member suggested the Cam Motion Lil Chopper 222/232 .595/.587 108+3*
It has the same overlap as the ASA at 11* with less duration (ASA 226/236 .600/.600 110*)
You might like that Cam Motion better. The ASA cam is through 7400 rpms I think.
Old Nov 4, 2019 | 07:09 PM
Bad01z71's Avatar
I've been looking into cam motion myself and will probably pull the trigger in do time. You don't find as much about them, but what you do find is top notch. With your truck being lighter 2wd and a 6.0 I think they'd set you up pretty good holler at them.
I was waiting for a re run with you and that Camaro lol good stuff.
Old Nov 5, 2019 | 03:00 PM
BlackPanther6.0's Avatar
i had great luck with the tick performance sns ls2 stage 1 cam 227/231 that has 7 degrees of overlap and made 400rwft-lbs of torque at only 3k rpm, the version 2 of the btr truck cam will actaully extend the RPM range due to more overlap. it will have a stronger mid range to top end for sure. get a high lift cam it will make more power everywhere
Old Nov 6, 2019 | 07:51 AM
RedXray's Avatar
100% Redneck
Cam Motion Lil Chopper on the way from Summit.
Thanks to all that replied!
ChadSr
Apr 15, 2018 09:27 AM
greer711
Mar 26, 2017 10:02 PM
07NBSChevy
Jun 10, 2016 11:11 AM
Sypher
May 28, 2016 09:58 PM
chevyguy7802
Mar 8, 2008 07:15 PM
