Cam swap suggestions
Old Jun 11, 2016 | 03:06 PM
Duramaxpwerdburb's Avatar
Default Cam swap suggestions
So I've pretty much have done almost every bolt on there is. I have a 2004 suburban 5.3...lifted on 38's, longtubes with cat delete, cold air, full magnaflow exhaust, 4.88 with posi-trac, e-fans, with a basic street tune. I primarily use it to tow my 25' toyhauler but im looking for some extra power. Im eventually gonna do the 80 trans swap and turbo it within a year but wanna do something now without swapping the converter. Any suggestions would be appreciated.
Old Jun 11, 2016 | 09:08 PM
Wolftrk99's Avatar
What converter do you have now??
Old Jun 12, 2016 | 12:05 AM
Stock 60e
Old Jun 12, 2016 | 12:15 AM
Wolftrk99's Avatar
May want to consider trans swap and converter before cam... But what are your goals and how long before you plan on the swap and the turbo etc??
Old Jun 12, 2016 | 10:39 AM
80 swap in 6 months,then by Jan turboed
Old Jun 12, 2016 | 11:03 AM
Wolftrk99's Avatar
Just think that putting a cam in for turbo would need a stall even running it na, unless you plan on two cam swaps, or can deal with no bottom end for the time being.... Think the stall and trans would be the better money spent first then cam and turbo at same time....
Old Jun 12, 2016 | 11:13 AM
rocknZ71's Avatar
I'm no expert but I'd agree with Wolf. Even with the 4.88's you've got a lot of tire and weight for that 5.3. If you cam for your current combo it would be less than optimal when the turbo is added and I'd imagine that a turbo cam for your combo will hurt you until it's turbo'd. Good luck whichever way you go and keep us posted!
Old Jun 12, 2016 | 07:25 PM
GREENSIERRA's Avatar
5.13s would have been a better choice for gears.
defanitly do a 80e swap before trying to add any power. A 278mm 3200 would make a noticeable fun factor increase and also still be able to tow
Old Jun 16, 2016 | 08:27 PM
Thx for the input guys. Really appreciate it.
mdwatts11
May 9, 2020 05:28 AM
simman22
Apr 24, 2016 09:43 AM
LSXTAHOE
Mar 29, 2016 02:46 PM
Furdkiller
Mar 21, 2016 05:30 PM
