cam swap...running rich?
Old Aug 22, 2010 | 12:27 PM
06Sierra2's Avatar
Default cam swap...running rich?
ok, so i finished my cam swap at about 0430 this morning. the truck started on the first try, had oil pressure instantly, and didnt die. with hpt just reading off the maf it was running just slightly rich. however, it seemed to be spitting out alot more exhaust gasses than normal and it smelled really rich. our eyes were burning just sitting outside behind the truck for a few minutes. is this something to be worried about? or do u think the tune is just slightly off and can be adjusted with the wideband?
Old Aug 22, 2010 | 12:36 PM
budhayes3's Avatar
PT's Slowest Truck
You probably just need the tune adjusted, you're now pumping more air and less vacuum and the PCM is compensating by adding fuel. What are the cam specs?
Old Aug 22, 2010 | 12:44 PM
06Sierra2's Avatar
224/224 .581 114lsa
Old Aug 22, 2010 | 01:13 PM
budhayes3's Avatar
PT's Slowest Truck
5.3 or 6.0? Either way, I'd think that much cam would definitely have an affect on the fueling...
Old Aug 22, 2010 | 01:25 PM
06Sierra2's Avatar
oh 5.3 sorry. yeah thats what i was thinking too. its a fairly large cam for a 5.3. i just wanted to see what all the pros on here thought. ima call my buddy tonight and see if we can put the wideband on and data log/tune
Old Aug 22, 2010 | 03:18 PM
Lextech's Avatar
Bigger cams will idle in a higher MAP area of the VE table because the cams don't produce as much vacuum as stock. So, they idle richer. Typically a larger cam wants less VE and more timing in the idle areas.
Jeff
Old Aug 24, 2010 | 12:01 AM
01GMC5.3's Avatar
well besides the issues how are you likein it ? I am about to put almost the same in mine
Old Aug 24, 2010 | 12:07 AM
Wheatley's Avatar
Truck Sponsor
That is normal,dial in your ve and maf tables using a wideband
Old Aug 24, 2010 | 05:32 AM
06Sierra2's Avatar
i gained 4 tenths and 3mph with the tune still slightly off. it lopes good with the cutout open and sounds great. feels like it pulls harder in the mid to top end. i am happy with it. i say go for it
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
