Cam swap with Heads on??
Old Apr 9, 2014 | 12:16 PM
69Camaro427's Avatar
Default Cam swap with Heads on??
So I bought a 210/218 on .551/.551 116lsa for my ecsb and want to run the stock lifters seeing as they only have 80K on them and will save me some money.
3 questions
1st I know I can spin the cam a couple of times to keep the lifter up in the trays, but is this reliable? I'm so scared of a lifter falling down.
2nd Do I need a special cam break in lube or just rub it in the 10w 30 oil that I use?
3rd Will I be able to drive it 10-15 miles to the tune shop?
Old Apr 9, 2014 | 12:23 PM
RS/SS 4.8's Avatar
10 Second Truck Club
I did the same and the lifters stayed up.
No just put it in n run. Thats what i did n still running 40k laters
Yes just cruising, no lead foot unless u want something bad to happen.
Old Apr 9, 2014 | 12:41 PM
I love technology haha so much easier to do a cam swap on these Ls motors than the old sbc
Okay cool I wasn't planning on taking it above 2000 rpm just grandpa baby driving over there
Old Apr 9, 2014 | 12:42 PM
ACLR8R's Avatar
I have always used the 3/8in dowels to make sure the lifters stay up. Just a little piece of mind.
Its a pretty mild cam, you'll be fine driving it.
Old Apr 9, 2014 | 12:50 PM
I have seen those before. I think I'm going to go to Home Depot and buy some 3/8" rods and weld a little stopper plate at the end
Old Apr 9, 2014 | 01:23 PM
Ferocity02's Avatar
The rods work well, I've also done the pen magnet method. I wouldn't trust the lifters to not fall. That would ruin your day.
Regular oil is fine.
It's okay to drive, the fuel trims will keep everything in check. It might be harder to get to idle if its a big enough cam. If you're replacing the valve springs they typically need several heat cycles to break in.
Old Apr 9, 2014 | 01:44 PM
Vortec350ss's Avatar
This.
And as Ferocity said regular oil is fine.
Old Apr 9, 2014 | 03:46 PM
Thanks guys just finished the spring swap and got the headers bolted back up. Notice those head studs Had the drive side head crack a year or two ago and went ahead and bought a used set of 862 and milled .03. Decided to put $70 Pro-Comp studs in it with new gaskets, and they were a B**** with the motor still in the truck. Notice the the dents on the fire wall?? haha had the transmission jacked up and still couldn't get the back two studs in so I had to relieve some frustration on my fire wall. lol I am never taking these heads off and my next head swap will be on an engine stand....
Old Apr 9, 2014 | 03:48 PM
Where are my pictures used photobucket
Old Apr 9, 2014 | 09:50 PM
AUTOT3K's Avatar
the last time I had my heads off I used head studs on the install and I agree with you 100%...if they ever have to come off again...the engine will be on a stand haha but for the record...you should've put the studs in after the heads were on!
