Cam Swap
Old Aug 22, 2010 | 12:40 AM
Littletruckbigstick's Avatar
Registered User
Question Cam Swap
I have a 5.3l that I am going to put a Edelbrock Performance Manifold Kit and a Thumpr Comp Cam and a 750cfm holley double pumper and a set of Comp Beehive Valvesprings in the stock heads. Dose any one think I will have any problems with this setup. Oh I forgot the MSD that gose with the manifold kit.
Old Aug 24, 2010 | 12:05 AM
01GMC5.3's Avatar
well you will gain power with the thumper cam it is mainly for sound but not as much as you could with other choices. what all is this going in ?
Old Aug 24, 2010 | 11:33 AM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a street rod setup...as mentioned, it will sound mean, but there are better more efficient cam options out there...
Old Aug 29, 2010 | 09:18 PM
matt29201's Avatar
i had a 86 silverado that i swapped a lq9 in with the edelbrock intake and msd 6ls ignition i used the edelbrock 2216 cam 230/237, 540 lift on a 110 lsa ran awsome and sounded great with a pretty rough idle. edelbrock said it was a perfect match for that intake on a 5.7 but im sure it would work great in a 5.3 with the right converter and gears. and with the 2216 cam you can run ls6 springs with no problem.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
