Cam Swap
I have a 5.3l that I am going to put a Edelbrock Performance Manifold Kit and a Thumpr Comp Cam and a 750cfm holley double pumper and a set of Comp Beehive Valvesprings in the stock heads. Dose any one think I will have any problems with this setup. Oh I forgot the MSD that gose with the manifold kit.
i had a 86 silverado that i swapped a lq9 in with the edelbrock intake and msd 6ls ignition i used the edelbrock 2216 cam 230/237, 540 lift on a 110 lsa ran awsome and sounded great with a pretty rough idle. edelbrock said it was a perfect match for that intake on a 5.7 but im sure it would work great in a 5.3 with the right converter and gears. and with the 2216 cam you can run ls6 springs with no problem.
GrooveCityZ71
Aug 31, 2015 12:05 PM
GreyChevy
Jul 7, 2015 08:57 PM
