cam/stall for a 5.3 s10
Old Jul 27, 2010 | 07:10 AM
jonnyboy's Avatar
Default cam/stall for a 5.3 s10
I'm parts gathering and it decision time.
I have a 2000 reg cab s10 and it will be stepside when finished (~3000-3200 lbs). I recently aqcuired a 5.3 engine and I already have a trick flow 220/224 .575" cam. It is going to be auto with either 3.73 or 3.42 gears. Will this be good cam for a semi-daily driver/weekend warrior? Also, what stall? Will this work well with a 100-150 shot of nitrous?
Also, how long before a 4l60e takes a poop in this setup with servos and a shift kit?
Any help will be appreciated, as I know little about this stuff.
Old Jul 27, 2010 | 10:35 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
that cam will be a nice cam in that motor with a 3200 stall verter. if it were me id do 4.10s but 3.73 will do. as far as the nitrous id say you be fine running that cam dont see why not. the 60E is hit or miss my buddy has a shift kit and servo in his 60E behind a cammed 5.3 in his 1500 rcsb he beats it pretty good and its been goin for over a year now since you'll be runnin the jug id say get a fully built one to be on the safe side IMO.
Old Jul 27, 2010 | 05:57 PM
chevysten's Avatar
I'm running a similar cam 222/228 581/588 and running a Yank SST3600 stall in my 98 reg/cab s10 and love it.I drive mine pretty hard everyday and I'm getting ready to install the juice to it(150 shot) I had my 60e built here localy(bigger clutches,servo,and shift kit)just so I want I have any probs with the nitrous.If you have any questions just send a pm and I'll be glad to help out.Good luck with the build,Mike
Old Aug 26, 2010 | 02:30 PM
12 Second Club
I'm interested to see how your build turns out, i have a 2000 ext cab s10 with a 5.3, basicly stock except sanderson headers and ls1 intake, the 4l60e is holding up with only a shift kit and servos. I'm looking at cams but can't decide, I dont want to lose my gas mileage, I average about 25mpg if i drive easy. What cam would you reccommend? (not trying to thread jack) I'm still learning about valvetrain engineering.
Old Aug 26, 2010 | 03:00 PM
smokeshow's Avatar
Mod with training wheels
If you upgrade the clutches, it should handle the power no problem. My truck weighs ~5800lbs with a built 60e and is putting down about 550rwhp, and it takes it like a champ. With a truck that light, I would stick with the 3.42 gearing. Those s10s come with 3.08 and 3.23 gearing from the factory, the 3.08s coming with the bigger 4.3L motor. Jumping to 3.73 or higher with a weekend warrior 5.3 is just unnecessary...it'll just burn the tires and you'll get nowhere.
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
pewter00
Sep 7, 2015 10:14 PM
Sdailey
Sep 6, 2015 10:26 PM
