Cam second opinion
Old Jun 23, 2011 | 03:01 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Get some good breathing heads for that 6.0, the stockers will be a choking point. As said before, that cam is too big for stock heads.
Old Jun 23, 2011 | 04:33 PM
budhayes3's Avatar
PT's Slowest Truck
He could send his current 317's to WCCH for a StageII treatment and a mill...or get some 243's with the smaller combustion chambers, and have them worked instead (WCCH offers both )
Since he's blown, he won't need to be trying to bump the compression up too high, so his current heads might work fine for him (after a good p&p of course)
Old Jun 24, 2011 | 01:42 PM
Nightmare04's Avatar
Well talked to my guy and he said he gave me the right specs and said that he has put bigger cams in 5.3's. Time will tell if this cam works out and if it dosnt he said we would go smaller.
Old Jun 25, 2011 | 09:34 AM
1989k1500's Avatar
You need a converter that stalls higher than 3200 for a cam that big or its going to be a slug outta the hole.
Should fix your traction issues though so thats a bonus.
Old Jul 11, 2011 | 09:14 PM
Well had some problems with the 5.3 so now this cam will be going in a lq9.
Old Aug 8, 2011 | 01:04 PM
Well took longer then I planed but finally got the swap done. The tune is not done yet due to it leaning out around 5500 RPMs but on 10lbs at that RPM it put down 516/508. Temp outside was 108. Getting back at sometime next week with final numbers.
kush killer
Feb 17, 2016 09:20 PM
2500ZL1
Jan 25, 2016 06:30 AM
urdone
Aug 18, 2015 12:17 PM
lawhitediamante
Aug 12, 2015 12:14 PM
Aboss
Jul 9, 2015 10:28 AM
