cam retainer plate bolt hole
Old Mar 3, 2016 | 04:15 AM
Jake75's Avatar
Default cam retainer plate bolt hole
During the process of changing my cam i stripped the head of the torx bolt. Tried to use a easy out to get the bolt out...drill broke inside the bolt and wouldn't budge. So i tack welded a bolt to the head of the stripped bolt it started coming out...until the head of the bolt snapped off! I ended up drilling the bolt out but in the process i got off center and drilled the threads out of right half of the hole. What can i do besides taking it to the machine shop so they can fill in the hole and re drill it? don't really wanna pull the motor out the truck.
Old Mar 3, 2016 | 05:16 AM
CF7GO's Avatar
Heli-Coil
Old Mar 3, 2016 | 07:30 AM
Jake75's Avatar
Thought about that but not sure if the Helicoil will have the bolt centered where I need it the hole I drilled is to the right not center
Old Mar 3, 2016 | 07:37 AM
CF7GO's Avatar
Only thing that comes to mind would be putting the plate back on and use it as a PILOT for the drill.
Old Mar 3, 2016 | 08:22 AM
Jake75's Avatar
Anyone know if I can fill the hole with jb weld and tap it after its fully cured?
Old Mar 3, 2016 | 08:27 AM
CF7GO's Avatar
You have a picture of how bad it is? Which hole/bolt was it?
Old Mar 3, 2016 | 08:56 AM
Jake75's Avatar
I'll have to get a pic when I get home but the bolt is basically drilled in half. When I took out the bolt there's about 1/4 of full thread on the bottom of the bolt the rest is 50% of the bolt
Edit- this is before I cleaned the hole out. There's shavings in the pic.
Old May 3, 2016 | 07:55 PM
Wolftrk99's Avatar
Thats ugly, know this is kinda old but did yiu end up fixing it???
Old May 3, 2016 | 08:26 PM
Jake75's Avatar
I got lucky with it! The oversized hole was the exact size i needed for a heli coil to i drilled it all the way and tapped it for a heli coil. It's holding great
fountain333
Jul 24, 2016 01:35 PM
Slow91z
20
Feb 15, 2016 03:51 PM
06 4.8
Feb 9, 2016 10:20 AM
embs2001
Feb 4, 2016 01:33 PM
santoy956
Dec 19, 2015 11:29 AM
