LQ9 Build
Old May 1, 2016 | 08:21 AM
KCodd's Avatar
Registered User
Default LQ9 Build
Im currently planning the build for my TBSS and cant decide on displacement. Are the sleeves on an LQ9 the same length as all other LS blocks? I dont want premature skirt wear from the stroke pulling the piston too far out of the cylinder and need to decide on stroke. The truck is going to either get a blower or 480 so itll definately see power and want it to live a long life.
Old May 1, 2016 | 05:23 PM
FFDP's Avatar
Long life with power = stock block with either mod of your choice.
Save yourself the money and just slap whatever you want on it. It'll handle 700+ whp with that engine on the stock bottom end.
This is how I would do it. Spend the money you save by running the stock motor on something else, like a built transmission or a rear end upgrade or for other better quality parts (injectors, fuel pumps, waste gates or whatever).
Old May 2, 2016 | 03:06 PM
KCodd's Avatar
Registered User
The truck already has a trans, converter, and fuel taken care of and now its the motors turn.
Old May 3, 2016 | 12:33 PM
53bowtie's Avatar
What are your hp goals?
Old May 3, 2016 | 01:09 PM
KCodd's Avatar
Registered User
I want something that has no problem living at 650-700 rwhp with the ability to hold more if I want to turn it up in the future. Id like a bottom end that will handle some miles also because I know Ill end up driving it a bunch for the first few weeks.
Old May 3, 2016 | 05:30 PM
Ken in AZ's Avatar
Stock LQ9 does that just fine, just throw a decent set of heads on it with some decent MLS head gaskets and you're good to go.
If you're looking to drop some coin, buy a forged 408 built for boost with some decent heads.
I just got done building an LQ4 427 stroker and for the same or less $$ and a whole lot less time I could have bought a 408 shortblock. My dumb a$$ had to "build" the engine because I thought it was cool at the time.
Old May 4, 2016 | 06:15 AM
KCodd's Avatar
Registered User
Thanks for the info. I know stock will handle it but I'm looking to do a rebuild anyway so I'm going to put a forged assembly in it
HDhotrod
Jul 19, 2016 02:57 PM
14BFF
May 23, 2016 11:38 AM
KB Silverado
Apr 12, 2016 11:23 AM
Rocked_Ram
Apr 5, 2016 06:36 PM
BigTex
Apr 5, 2016 11:05 AM
