cam recommendation (2 questions)
Old Mar 12, 2006 | 11:16 PM
reveille5's Avatar
Originally Posted by UnrthdxDream
revelie you should definately give us the specs on your cam when you get it in.. i was lookin at possibly gettin the ultra torque from vinci but im curious what they set you up with for a custom grind for more low end torque...
Here are the specs:
Duration @ .050
Intake 219
Exhuast 223
Lift intake 564
Lift exhaust 474
lobe separation 112
4 degrees advance on cam
intake centerline 108
A company in Baton Rouge, Cammotion, is doing a custom grind. I told them I wanted more low end torque and throttle response and this is what they came up with. White1, a memeber here, recommended me to call. I live in the New Orleans area so Baton Rouge is not far away.
Old Mar 13, 2006 | 05:33 AM
tdrumm's Avatar
Originally Posted by revelie5
Here are the specs:
Duration @ .050
Intake 219
Exhuast 223
Lift intake 564
Lift exhaust 474
lobe separation 112
Is the .474 exhaust lift a typo? .574 seems like it would be more in line. Looks like a nice cam though. Cammotion knows their stuff.
Old Mar 13, 2006 | 08:24 AM
reveille5's Avatar
Default cam recommendations
I called this morning and confirmed exhaust lift being .474. Then the rep changed the exhaust to 222 from 223 and the lift exhaust from 474 to 551.
With the prior set up, they (cammotion) stated I could use stock springs. Now they recommend going with new springs (off an ls6).
Any agree with changes?
Basically looking for a mild cam with low end torque for better throttle response.
Old Mar 13, 2006 | 08:34 AM
white1's Avatar
Well, i dont know everything about cams, but
1. Cam motion knows their ****,and
2. Thats probably to keep a little more heat in the cylinder to help with making some low end torque.
Did Kip, or Terry tell you how many RPM to sping this cam?
Old Mar 13, 2006 | 08:35 AM
reveille5's Avatar
Default cam recommedation
White1,
I believe it was Danny. He is comming in at 9:00 and I will call to confirm the changes.
Old Mar 13, 2006 | 08:38 AM
white1's Avatar
Yea, that lift looks a little better. Not sure who Danny is, but I trust Kip with the people he hires. I think the LS6 springs would be good insurance anyway. If you have troubel finding them, or plan to go bigger later go ahead and get some comp 915s, or 918's. I got 918's and thats what it seems most people get.
Old Mar 13, 2006 | 09:14 PM
FarmerBeau's Avatar
Sexy Party Mod
918s fo sho!! haha
Old Mar 13, 2006 | 09:15 PM
reveille5's Avatar
Originally Posted by FarmerBeau
918s fo sho!! haha
Yeeeaaah, boyyeeeee.
Old Mar 28, 2006 | 01:16 PM
NastyNate420's Avatar
good thread, id like to know the same info...with the exception...i don't race my truck (2000 Z71), and don't really plan on getting a stall...i'd like to get a cam that helps out the entire powercurve, but mainly downlow...
Old Mar 28, 2006 | 01:29 PM
white1's Avatar
Too late your hooked. I have a 2000 Z-71 too. Fixing to be mid to low 13's Ayn cam you get worth the installation time is gonna need a higher stall converter. If you get a good converter, you wont notice it until you get on it. Putting a nice little converter will really let it get in the powerband faster, and if you stay reasonable it shouldnt affect normal day to day driving. Id think you would be happy with something like a 216/220 Comp XER and about a 2600 stall converter.
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
76k10chase
Jul 17, 2015 01:48 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
