cam question????
Old Sep 19, 2006 | 04:54 PM
phatboy's Avatar
Default cam question????
part # 12560968 00 vette .500/.500 207/198 115.5lsa
part # 12499224 ls6 springs
going in a 00 5.3 ecsb 2wd anybody see any problems with this combo going in my truck any advice will be appreciated any other parts i may need?
one more question can i use a longer pushrod to add some lift to this cam?
Old Sep 19, 2006 | 06:15 PM
icedenali's Avatar
use ls6 cam 02 and later. it's got .550/.550 lift. I got it in my truck. it's running pretty good at high RPM.
I got ported cylinder heads from west coast cylinder head (richard) super nice guy!!!
as far as pushrod, I used 7.400 but it won't change lift open, if you want to get higher lift. You might want to change rockers arm to 1.8 from stock 1.7
should get about .03 more lift up.
also you have to change it to new timing chain. although you can use stock again.
Then you have to start change your tranny!! to run the power to wheel.
Good luck.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
