cam lsa
Old Dec 15, 2008 | 10:02 PM
Go5.3tt06's Avatar
Default cam lsa
I want to know for cam on N/a engine and later do turboed which is good to have number of LSA. I still think about 212/218 But want to find right LSA for n/a and turbo. Which I not have to swap other cam when I get turbo. I can see alot people like run ls6 cam out from corvette as well.
Old Dec 15, 2008 | 10:27 PM
00Silv4.8's Avatar
iirc turbo's like bigger LSA's like 115 or something like that. N/A we go for lower LSA for the sound and lower end power.
Old Dec 15, 2008 | 10:29 PM
Mangled03gmc's Avatar
Baltimore Whore
You want a high number(less overlap) for turbo and blower set ups, lower number(more overlap) for NA set ups... Unless you want to do a cam swap put in a cam that will work for the FI now or on a LSA that will work with it when you do....
John
Old Dec 15, 2008 | 10:30 PM
BlackGMC's Avatar
Resident Retard
I believe turbo's and Superchargers like less overlap... LSA+Duration contribute to overlap...
Old Dec 15, 2008 | 10:37 PM
00ChevyScott's Avatar
Wearin' da big hat
z06 cam...
Old Dec 16, 2008 | 11:18 AM
banker099's Avatar
mine is a 115 and has a nice sound to it and should work well if/when i go supercharged
Old Dec 16, 2008 | 11:32 AM
zippy's Avatar
You'll want to keep it at 114 or higher.
Old Dec 16, 2008 | 11:34 AM
JFOLM's Avatar
yeahhh.
Old Dec 16, 2008 | 11:38 AM
circusboy's Avatar
Old Dec 16, 2008 | 02:01 PM
Go5.3tt06's Avatar
I spoke to Texas-Speed. They offer me to run 212/218 But I forget LSA number. Either on 114LSA would be good on N/A then later do turbo. Do I have to change cam for LSA to match turbo. What size z06 cam is? I think 212/218 would make better power than z06 cam. I do tow sometimes. This is drive daily, and street/strip. WHat number LSA can do both? I want it sounds better lope but as hard CHOP idle which I would not want that.
