cam lsa
Old Dec 28, 2008 | 02:52 PM
  #41
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by ForcedTQ
Sorry, I have to correct you, 114 is not overlap, but is rather the "LSA" or the angle between the peaks (centerlines) of the Exhaust and Intake cam lobes. Overlap is measured on a graph when you take the lift values of a cam lobe and plot them over degrees of rotation. When overlap in a cam exists you will see the exhaust lobe in the act of closing (but not closed all the way) and the intake lobe will start opening. The degrees of overlap are measured when this condition exists (when the intake lobe opens before the exhaust lobe is closed) from the point at which the intake lobe opens to when the exhaust lobe finally closes. LSA is just the angle between the centerlines of the two camshaft lobes.
Not disputing that the cam will work for F.I. for clarification, as I have not personally tested that cam nor have I seen it's geometry.
No biggie. Yes I understand, I should have been more clear. That number justifies teh overlap... A cam of 112 lsa has more overlap then one on a 114lsa...
Old Dec 28, 2008 | 03:02 PM
  #42
LS1TRUCKGUY's Avatar
114 lsa will work ok with n/a or boost. Go with it. You wont regret it
Old Jan 5, 2009 | 03:08 AM
  #43
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Go5.3tt06
How can we deal with this? I sitll confuse about overlap. I dont know which one SIMPLE for me to run. No matter what which one can work on N/A and turbo. I still want to atick with 212/218 but I still struggles with LSA. Texasmotorsport offer me the torquer v.2 Camshaft but didnt tell me a lsa. http://www.texas-speed.com/shop/item...d=174&catid=49
2600 stall umm How about 3000 or 3200 If I go with 4l80E tranny? Trailblazer coverter you mean Trailblazer SS?
Copied and pasted from there Site...
Texas Speed Torquer v.2 Camshaft
TSP XS Series Camshaft: Torquer 2 232/234, .595"/.598" Camshaft With Your Choice of Lobe Seperation
You get to chose which LSA you want....
Old Jan 5, 2009 | 03:51 AM
  #44
1FastBrick's Avatar
Texas Speed 224/224 XE Camshaft
Item#:
25-224XE
TSP Custom 224/224, .566"/.566" Camshaft With Your Choice of Lobe Seperation
If your set on something larger then the 212/218, This would probally be a better choice for you for a DD combo and for later adding a Turbo.... Stay with a 114LSA. The 5.3L heads will reach there Peak flow around .550 lift any way
At a certin point you hit point were you will stop gaining any thing.... You will actually start to lose power on the bottom end.... remember A truck intake and the stock truck heads will stop flowing at a certin point. I highely recomend you purchase the following Book,
"DYNO-PROVEN GM LS1 THRU LS7 PERFORMANCE PARTS"
If you look on page 77 you will see what I mean About the point of demenishing returns.
They test a XR265HR Vs. XR281HR on AN LS6 Crate engine...
.212/.218 .525/.529 114LSA Vs. .228/.230 .571/.573 112LSA
The smaller cam made more useable tourqe up to 5300 RPM By as much as 20 FTLB more.
Same thing if you look at the HP out put. The smaller cam stays slightly above the Larger one untill around 4700 rpm...
On a daily driver, How much time do you actually spend up past say 3000 rpm??? maybe 5% of your actuall driving... same thing when your towing were you actually need that extra power down low...
2500ZL1
Jan 25, 2016 06:30 AM
2500ZL1
Aug 14, 2015 12:23 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
