Cam and L92's
Old Feb 20, 2011 | 01:18 PM
viciousknid's Avatar
Where's the Beef?
Default Cam and L92's
So I fear I may have made a mistake. Hoping someone can help me understand the madness.
I ordered an EPS tt3 for 4.8-5.3 cathedral port heads. I'll put it in my 5.3 and I later want to put this same cam in my 408 with L92 heads.
Can I even do that?
From what I've been reading there may be PTV clearance issues if not using a cam that is designed for L92 heads. What makes the l92 require a different cam?
am I going to need to order a new cam when I'm done with my build?
The 408 will likely have -15cc dish pistons with L92 heads and the cam spec on the tt3 is 224/230 609/607 111.
any info on this whole head n cam requirement is wanted. Don't I even need to make sure i'm ordering pistons for L92 heads?
Old Feb 20, 2011 | 01:39 PM
southern_chevy's Avatar
Most of the time the poor exhaust flow of the heads is the reason for there own cams. Cans help you on the ptv question tho
Old Feb 20, 2011 | 02:09 PM
skeet's Avatar
Can I even do that?
theres no special cams for l92 heads, i ran a 232/238/612/607/112 +2 advertised 230/238 and a 235/239/624/624/113+1 BUT on a LQ9 shortblock. these are NA spec'd cams
if you dont mind me asking what are you after in your setup ?
Old Feb 20, 2011 | 06:31 PM
Where's the Beef?
Shooting for 450-500rhp on the 408 with l92s milled 30, ls3 car intake, -15cc dish pistons. Somewhere around 10.1:1 with the ability to do heads n cam swap in the future for turbo. Goin to a stock l92 should brin it back down to 9.6:1
Old Feb 20, 2011 | 06:32 PM
Where's the Beef?
The stroke should take care of any tq I need but want it to scream up top
Old Feb 20, 2011 | 06:38 PM
BlackGMC's Avatar
Resident Retard
You need to look at the DCR with that cam and your 408 engine specs...
Old Feb 20, 2011 | 08:26 PM
Where's the Beef?
Dcr?.?
Old Feb 20, 2011 | 08:30 PM
skeet's Avatar
he may have meant SCR static compression ratio instead of dynamic compression ratio, you wanna keep your DCR above 8.00 or it will feel like a dead dog leaving on launch
Old Feb 20, 2011 | 08:35 PM
BlackGMC's Avatar
Resident Retard
Dynamic Compression Ratio. Google it and look for a calculator... plug in the numbers for your 408 and that cam and post up what it comes back with... IMO anything over 8.5-8.6 is toooo much...
http://search.yahoo.com/search;_ylt=...8&fr=yfp-t-701
Old Feb 20, 2011 | 08:43 PM
fastrt's Avatar
11 Second Truck Club
Dcr?.?
yes sir, DCR so you can keep it pump gas friendly. If my calculator is right, with a .060 head gasket, 4.30 bore, 4" stroke, adv -.006 out of the hole, 64cc chamber, and -15 dish piston it comes to a 8.06 DCR. As long as the cam has no advance. At 111+4 it is around 8.32 DCR. I say go for it, stick with a stock H/G. DCR should be around 8.5 like Corey said....
