Cam bearings
Old Sep 18, 2016 | 07:49 PM
Lowexpo's Avatar
Default Cam bearings
So I get my motor apart to find my cam bearings are worn. Question is, pass. side oil hole in bearing has no hole behind it? Is this normal? Anyone know a good machine shop in or around Huntsville Al.? Besides R&R and Huntsville Engine.
Old Sep 18, 2016 | 08:23 PM
Gadgetized's Avatar
That's normal. I actually see much worse usually.
Old Sep 18, 2016 | 10:43 PM
Wolftrk99's Avatar
Notmal, but while its apart they are worth replacing, and yes only one oil hole lines up with the oil galley, the spot where they are joined together goes to the top saves from having to put them a specific direction aside from the joint going up... If you replace them look into a set of coated bearings... Is that a gen 3 or gen 4 engine? And cast or aluminum?
Old Sep 18, 2016 | 11:26 PM
Lowexpo's Avatar
It's a gen IV cast motor. It blows my mind the factory does that. Ive seen guys using several different brands of bearings. Guessing King or Clevite? Is Durabond any good? This is a daily driver that will hopefully see a little boost one day.
Old Sep 18, 2016 | 11:34 PM
Wolftrk99's Avatar
Gm has a bulletin on an updated set of coated bearings for the gen iv engines... And they made them all wide bearings.... There were two sizes listed, as far as width goes, for stock replacements... Can get part numberif youd like, or youd rather i think its durabond coated bearings....
Im bored....
All aluminum and iron blocks with first design camshafts
19260874-position 1 and 5
19260875-postion 2 and 4
19260876- position 3
2nd design cam with late 2009 and up cast iron block
19260877-position 1 and 5
19260878-position 2 and 4
19260879-position 3
Old Sep 19, 2016 | 07:38 AM
Lowexpo's Avatar
Cool, thanks Wolftrk99. Hope I can get it to machine shop in next couple of days.
JoshC04
Nov 13, 2016 08:35 AM
renright83
Oct 17, 2016 09:05 PM
Byrdman11
Sep 19, 2016 05:41 PM
JordanH
Sep 18, 2016 03:05 AM
lxcoupe
Sep 14, 2016 01:45 AM
