Cam Balancing
Old Apr 16, 2006 | 07:47 PM
TIM Z's Avatar
11 sec. Truck Mod
good info, i didnt know they did that. I d love to see some of the tricks these cup teams use.And BTW , Back then they didnt want me know i'm hot they all on me!
Old Jun 8, 2006 | 11:37 AM
CamKing's Avatar
Originally Posted by mjhoward
It isn't something I would ever even consider. Not even on a 7500rpm race engine. For what I do, it isn't worth it. It is amazing the things they will do for 3hp .
Have you ever seen someone break a timing chain or valve spring?
That's what valvetrain harmonics can do.
We see HP gains on balanced cams from 5,600rpm on up.
On Hydraulic roller cams we see as much as a 400rpm gain engine rpm.
Old Jun 8, 2006 | 11:41 AM
CamKing's Avatar
Originally Posted by vanillagorilla
I've always wondered if they balanced cams. I guess not...I've seen cams being ground and machined and it doesn't look like they're out of balance on a lathe, but then again, they're fixed/supported in several spots.
I see 3hp for $99 being an amazing deal at that level. 3hp adds up to a lot in a 500mile race. Besides you also get the added benifit of having a more reliable engine. So what's next harmonic dampeners for cams?
The average cam is out of balance by 3-4 ounce-inches at 400rpm.
As for harmonic dampeners for cams, some of the IRL engines ran them a few years ago when they went from chain drive to gear drive.
Old Jun 8, 2006 | 11:43 AM
CamKing's Avatar
Originally Posted by eallanboggs
Camshafts are unlike crankshafts in that they do not have filets where they can be bored to add heavy metal plugs for the purposes of adding weight or drilled for the purpose of subtracting weight. That being said where would you do the balance adjustment? Certainly not on the cam lobes themselves nor would you want to drill at the cam bearing location. So what is left to drill? Not much.
We drill on the sides of the cam journals, and we also sometimes make a counterweight that bolts onto the timing gear.
Old Jun 8, 2006 | 02:54 PM
vanillagorilla's Avatar
Who is we? Who do you work for CamKing? Welcome!
Old Jun 8, 2006 | 08:07 PM
TurboGibbs's Avatar
Never said that it wasn't worth it to somebody, I said it wasn't worth it to ME and probably not the average shade-tree gearhead. Good info though.
Old Jun 8, 2006 | 08:27 PM
CamKing's Avatar
Jones Cam Designs
Thanks for the welcome.
Old Jun 8, 2006 | 09:37 PM
moregrip's Avatar
what a rush!
Jones Cam Designs
awesome, glad you stopped by and thanks for the insight
Old Feb 14, 2008 | 09:48 AM
Moddoo's Avatar
TTT
just came across this again.
Anybody try it yet?
Three6GMC
Nov 5, 2015 10:02 PM
Ls3silverado
Jul 31, 2015 04:22 PM
bgray
Jul 23, 2015 10:56 AM
