Cam Balancing
Originally Posted by mjhoward
It isn't something I would ever even consider. Not even on a 7500rpm race engine. For what I do, it isn't worth it. It is amazing the things they will do for 3hp
.That's what valvetrain harmonics can do.
We see HP gains on balanced cams from 5,600rpm on up.
On Hydraulic roller cams we see as much as a 400rpm gain engine rpm.
Originally Posted by vanillagorilla
I've always wondered if they balanced cams. I guess not...I've seen cams being ground and machined and it doesn't look like they're out of balance on a lathe, but then again, they're fixed/supported in several spots.
I see 3hp for $99 being an amazing deal at that level. 3hp adds up to a lot in a 500mile race. Besides you also get the added benifit of having a more reliable engine. So what's next harmonic dampeners for cams?
As for harmonic dampeners for cams, some of the IRL engines ran them a few years ago when they went from chain drive to gear drive.
Originally Posted by eallanboggs
Camshafts are unlike crankshafts in that they do not have filets where they can be bored to add heavy metal plugs for the purposes of adding weight or drilled for the purpose of subtracting weight. That being said where would you do the balance adjustment? Certainly not on the cam lobes themselves nor would you want to drill at the cam bearing location. So what is left to drill? Not much.
Originally Posted by CamKing
Have you ever seen someone break a timing chain or valve spring?
