Cam advice
Old Mar 24, 2006 | 11:52 AM
FarmerBeau's Avatar
Sexy Party Mod
Might be pushing it with the 918s but i would still run them for the time being and if you noticed any float, then switch over to 921s or another stouter spring.
Old Mar 24, 2006 | 02:10 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
IMO get the 921s and be done with it.
Old Mar 24, 2006 | 02:14 PM
moregrip's Avatar
what a rush!
Originally Posted by AdioSS
for a 6.0L with a blower in a truck with an auto, I'd suggest something around 224/236 on a 115. That would also work well for a nitrous motor too.
where did you get a recommendation like that from?
Old Mar 24, 2006 | 04:00 PM
02sierraz71_5.3's Avatar
I would keep the lsa at least 116, I would look at LPE gt2-3 and pattern you cam after it just with more duration and lift, keep the valve events the same Id expect you to pickup around 60rwp with something like that on 5-7psi boost.
Personnaly Id get 216/230 on a 118 with around .62x lift and use the very similar valve events that lpe uses on thier gt2-3
Old Mar 24, 2006 | 10:51 PM
Originally Posted by Blow03SS
Im looking to install a new cam and stall. As for the cam, on a scale of 1 to 10...10 being most agressive, I would like to be a 8. I was thinking about doing a Yank 3200 stall. I have no idea what I would need with the Vortech.
I have a 228/234,115+4,.588/.598 Comp cam that I removed from my truck,it idled with a slight lope about 750rpm and made good power from about 1500 to 6600rpm.The problem I had was low manifold vaccuum about 10" screwing up the bypass on my Radix setup,if you are interested I will sell it cheap,the lobes are in good shape and I'd take $100 shipped if you are interested.
ARC
57
Feb 21, 2022 10:54 AM
Castro45
24
Jul 31, 2015 07:13 PM
sauldgold
Jul 23, 2015 02:15 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
