Cam
Old Jan 15, 2016 | 01:45 PM
Dbar72's Avatar
Registered User
Default Cam
I need some help rebuilding my 2002 1500HD 6.0L. I'm getting my heads ported and polished, shorty headers, cold air intake, new coil packs along with new wires. I'm wanting a cam something to sound good and can tell I have one. Can anyone help me with this? I get lost with choosing cams
Old Jan 15, 2016 | 01:53 PM
FFDP's Avatar
I'd skip the shortys and go long tubes. Shortys aren't worth the money to me.
And do you want to keep the factory stall with this cam?
Old Jan 15, 2016 | 02:08 PM
Dbar72's Avatar
Registered User
I'll get long tubes then. Im gonna be daily driving it so I don't know if I need a after market stall? Is this something I need instead of factory stall?
Old Jan 15, 2016 | 03:47 PM
gamble686's Avatar
Circle D has some great options for something that will fit all your needs. I would recommend something like a 222/226 if you get a stall. If you stay factory I would go more mild like a 216/220
Old Jan 15, 2016 | 04:56 PM
Dbar72's Avatar
Registered User
Converter Diameter: 278mm - 11"
Stall speeds 2600 to 3200 RPM
Hand TIG Welded
High Carbon Spun Wound Lock-Up Clutch Lining
Heavy Duty Torrington Bearings
Exclusive CDS Bearing Retainer
LS Bolt Pattern
Old Jan 15, 2016 | 04:57 PM
Dbar72's Avatar
Registered User
Is something like this I would use to get a better stall?
Old Jan 15, 2016 | 06:21 PM
Dbar72's Avatar
Registered User
Hand TIG Welded
LS Bolt Pattern
Is this what I need to have a good stall? Will it be good for everyday driving?
Old Jan 15, 2016 | 07:19 PM
Dbar72's Avatar
Registered User
273/279 .581 hydraulic roller by comp. is that something I can run?
BLOWN 364
Jan 29, 2016 10:31 AM
travieso
Jan 2, 2016 04:18 PM
Blwn99x
Dec 26, 2015 01:10 PM
mikeyjm1
14
Dec 21, 2015 03:22 PM
bradley753
Dec 18, 2015 09:22 PM
