Cam Gurus talk to me
Old Dec 18, 2015 | 05:56 PM
mikeyjm1's Avatar
Default Cam Gurus talk to me
So some of you know I'm deployed so I have tons of research and What-if time on my hands.
I have a habit of trying new and different things; for instance my drive train and suspension...
I know most of the recommended cams but love to be different so I poke around at what I don't see done yet.
I have seen great results here and there from the Lingenfelter GT2-3 but I'd like bigger. So I look and compare their stuff and find the GT1. And cant find much on any trucks running it.
Lingenfelter GT1 Hyd Roller Camshaft 350-383-427 LS1, LS2, LS3, LS6 - Lingenfelter Performance
Stock 5.3 in my signature. I have a new Yank TT3000 waiting and some low mile LS7 lifters. How would It perform?
Old Dec 18, 2015 | 06:02 PM
Vortec350ss's Avatar
Tough to say without knowing the advance in the cam, but if you're staying NA I would without hesitation say you can do better...
Old Dec 18, 2015 | 06:18 PM
mikeyjm1's Avatar
I would like more explanation of why this wouldn't be a good one. I may go FI someday but it'd be a while. And give me other suggestions and why? I'm trying to learn.
Old Dec 18, 2015 | 06:27 PM
As I mentioned its hard to really criticize this cam without knowing how much advance is ground in.
But for a NA cam it has a lot of unnecessary exhaust bias. That usually means its pushing the exhaust valve open sooner than it has to be. In a NA motor that can hurt your power curve. It may make it carry longer, but your mid range suffers. If there is no advance then its not as much of a concern, but it pushes the intake event late enough that it will be a very high revving cam in a 5.3.
For your truck with as heavy as it is I would be looking to something in the ball park of a 218/220 112+3
Old Dec 18, 2015 | 07:39 PM
mikeyjm1's Avatar
Found the card. Can you tell me more. I can be talked out of it. I just want to learn as I go.
Old Dec 18, 2015 | 08:53 PM
mhotrodscooter's Avatar
I got two friends that run the gt2 and their both slow.
Old Dec 19, 2015 | 12:49 AM
The 42* intake close it way too late for what you want. It'll be a dog. It'll pull decent RPM but it'll be a dog. The whole combo is just kind of wrong...
Old Dec 19, 2015 | 12:56 AM
mikeyjm1's Avatar
Fair enough. Thank you.
BTR Truck Stage III Camshaft - Brian Tooley Racing
Tell me about Brian Tooley's Stage 3 Truck cam...
I've seen a couple online run it, even say they like it but, nothing critical or constructive saying why or how much power?
Old Dec 19, 2015 | 05:56 AM
madmann26's Avatar
I run something similar in mine. It pulls super good above 3200 or so.
It might be OK with a stock converter but I would do a stall just in case.
Old Dec 19, 2015 | 08:59 AM
mikeyjm1's Avatar
Like I said in the initial post I've got a 3000 stall Yank waiting at the house...
