Which Cam??
Old Dec 18, 2005 | 09:12 PM
Default Which Cam??
Pondering on which cam to get for my truck? My mods are radix,AS&M Lt's,flows dumped over rear axle. Just wondering what works best with this setup?
Old Dec 18, 2005 | 09:56 PM
PappyDan's Avatar
Tribe Shaman
their is a cam made for the radix, maybe blownchevy will chime in with the number
Old Dec 18, 2005 | 11:57 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That one is the GT2-3 I think, made by Lingenfelter if I remember right. Idles like stock. BTW which engine is in your truck? That will help guys give better advice. And what future mods are you planning?
Old Dec 19, 2005 | 06:35 AM
ZR1 DREAMING's Avatar
That's the one; LPE GT 2-3. Designed specifically for use with the MagnaCharger Radix.
Old Dec 19, 2005 | 08:46 AM
ap2002's Avatar
I believe he has a VHO...
Old Dec 19, 2005 | 01:25 PM
hellbents10's Avatar
LS1Tech Sponsor
thats a nice cam for a Radix truck. Vince went 12.7XX with his Silverado SS with a Radix, 2.8 pulley and that cam.
Old Dec 19, 2005 | 01:58 PM
The engine is the 6.0!!
Old Dec 20, 2005 | 09:17 PM
Last Call's Avatar
TOTM: January 2007
I just bought the gt2-3 cam for my radix 5.3 combo. It is actually on sale from Lingenfelter for $399.00 shipped to your door with valve springs and retainers. I heard it is an awesome cam for the radix even thought lingenfelter recomends there gt 7 cam. gt7 has more exhaust duration and a bit less lift.
Blownchevy seen 44rwhp with his cam and tuning afterward, but that was in a 5.3.
The only person that I have seen with a gt2-3 cam in a 6.0 was CHarris. He said that the cam worked awesome and was even better than his Cheater (sp) cam that he previously installed, and that cam was larger. I would PM him him. If you are not careful which cam you purchase, you may have driveability problems such as low vacuum at idle which mau cause your truck to die when using accesories.
Old Dec 21, 2005 | 07:09 AM
Their are many running that cam with a Radix on an LQ9, and they are all happy with it. You will be too... great mid and high range power over stock.
Old Dec 21, 2005 | 07:30 AM
Holty's Avatar
Notorious BIG
how about the off idle - low end power with that cam? how does it compare to stock? is there any noticeable "lope" at idle?
