build advice
Old Jan 27, 2010 | 01:23 AM
sando's Avatar
Default build advice
hey guys i'm currently running a lq4. i'm building a new setup here in a few weeks and i wanted to know the pros and cons of a 370 vs. 383. and info. help or suggestions would be appreciated
Old Jan 27, 2010 | 10:44 AM
cmiller's Avatar
some 5.3 bored to 3.905 the walls are to thin. i ran into that problem and i wouldnt do it.
the price difference between a 408 and 383 are couple hundred bucks for the blocks.
Old Jan 27, 2010 | 08:42 PM
sando's Avatar
correct me if i'm wrong but i shouldn't run into this problem if i'm using my 6.0 block
Old Jan 28, 2010 | 07:48 AM
dirt track racer 81's Avatar
cant build a 383 out of a 6.0. the main difference between a 408(6.0 block X 4in stroke crank) is the $1k crank shaft. imo stay with a 370 unless you got the money to buy the crank
Old Jan 29, 2010 | 10:05 PM
sando's Avatar
good to know i think i'm going with the 370
flatblack83
Jan 3, 2026 07:10 PM
6.0l RST
Nov 23, 2015 11:30 AM
gaps
Oct 15, 2015 02:53 PM
USMCvet0311
Aug 14, 2015 10:28 PM
