Broke a rocker arm bolt...
Old Mar 10, 2010 | 07:32 PM
TIM Z's Avatar
11 sec. Truck Mod
Default Broke a rocker arm bolt...
And tried to Drill it out , Tap and Helicoil it, but the Helicoil wont hold.
And i dont trust it running High RPM's anyway, so i need a new head.
I currently have stock 5.3 862's.
I have my cam , and am going to do a front mount Turbo down the road.
Should i just buy a used stock head?
Or should i upgrade to a better set of heads now?
What if any do you guys suggest?
I cant afford to break the bank, but am just looking for a nice upgrade since i need to change a head anyway?
Thanks!!!!!!!!!
Old Mar 10, 2010 | 07:47 PM
sonoma43's Avatar
How did you break a rocker arm bolt off?
I would say look into patriot heads, for the money they are a good choice.
Old Mar 10, 2010 | 07:57 PM
ChevyTruck's Avatar
something else
If you have the time and extra money you should just do the new heads now. That sucks that happened to you.
Old Mar 10, 2010 | 08:16 PM
TIM Z's Avatar
11 sec. Truck Mod
I over tightened the bolt, i think it also had a "bad spot" or imperfection in it.
And yes it sucks
If i can afford it i love to upgrade, even to a better factory head if Possible, just need advice thanks!
Old Mar 10, 2010 | 08:38 PM
charcold-bowtie's Avatar
imo buy a stock head for 50 bucks and run. What the point of expensive heads when your gonna blow air through it. Just my 2 cents
Old Mar 10, 2010 | 09:13 PM
zippy's Avatar
If you had the budget I'd do the patriots, but that's a tough call. TJ probably has a set of 862's sitting around.
Old Mar 10, 2010 | 09:15 PM
BlownChevySS's Avatar
I have a set of 317s that just had a valve job done with less than 50 miles on them I'll sell you cheap.
Old Mar 11, 2010 | 05:19 AM
JakeBrakeIH's Avatar
I agree, its not gonna be as important seeing your gonna be going FI and shoving air down its throat.
Old Mar 11, 2010 | 02:45 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Hard to beat 317s
Old Mar 11, 2010 | 03:21 PM
brent5631's Avatar
Originally Posted by TurboBerserker
Hard to beat 317s
If he does 317 heads he will drop about a full point of compression. which wouldn't be good for staying N/A.
