bringing block to machine shop tomorrow, what should be done?
Old Feb 18, 2007 | 05:08 PM
adam1803's Avatar
Default bringing block to machine shop tomorrow, what should be done?
Im building a forged 370 for turbo use. Obviously the block is getting bored .030, install new cam bearings and cleaned up. Is there anything else i need to have the machine shop do while its there?
Old Feb 18, 2007 | 05:13 PM
balance the rotating assembly since you will be getting new pistons at the very least
Old Feb 18, 2007 | 05:29 PM
adam1803's Avatar
i don't have my pistons yet, but of course that will be done. Right now im just bringing them a bare block.
Old Feb 18, 2007 | 08:22 PM
Have you talked to the machine shop? I was recommended to bring my pistons and stuff in with them because some times the precision of the pistons is off and they prefer to do the bore and hone to the spec of the piston to ensure the tightest fit. for example- your 4.030 piston could actually be 4.03001. They would want to hone accordingly.
Old Feb 18, 2007 | 08:41 PM
adam1803's Avatar
no i haven't talked to them yet. I guess i'll check with them in the morning.
Old Feb 18, 2007 | 09:24 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I'm building a normally aspirated 408. I took my pistons, rods, crank and cam to the machine shop. That way they could mic the pistons to bore and hone the cylinders to the correct clearance. I also bought my main, rod and cam bearings from the machine shop. That way, they could mic everything sell me the right bearing shells (I will have about 2.5 thousands on rods and mains). After the machine shop installed the cam bearings, they verified the clearance with the cam journals. When this work was completed, I took the pistons, piston pins, rings, rods, rod bearings and crank to another shop that specializes in dynamic balancing. They got the pistons and rods to be the same gram weight and did the math to set up the bob weights to balance the crank.
I had the block sonic checked, cleaned, bored/honed, mains align honed and decked the block to 9.230". As a minimum, you could just have the cylinders sonic checked, bored/honed, install cam bearings, and check main alignment and deck flatness.
What are you going to do for pistons and rods?
Steve
Old Feb 18, 2007 | 09:33 PM
adam1803's Avatar
I've got a set of 6.125" Eagle H-beams and haven't decided on pistons yet. I haven't been able to find any off the shelf that will give me 9.0-9.2 compression with 72cc heads so i think i may have them made.
Old Feb 19, 2007 | 08:33 PM
LS1 Tech Veteran
I ended up getting some custom Wiseco -18 cc pistons. You are right in that you won't find the shelf pistons you want for the CR that you're looking for with a 72 cc combustion chamber.
Steve
Old Feb 19, 2007 | 08:59 PM
adam1803's Avatar
i ended up getting a -15cc pistons, i'll be right about 8.7 CR
Idryfly5
Sep 2, 2022 08:55 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
USMCvet0311
Sep 4, 2015 09:43 PM
