boring a 5.3l to a 5.7?
Old Nov 14, 2013 | 06:12 AM
zero2sixT's Avatar
If you're going to run a mild cam, theres no reason to run a huge amount of compression.
What is this going in? Is it a DD?
Old Nov 14, 2013 | 12:25 PM
53bowtie's Avatar
Originally Posted by emmerich5.3
I think somewhere along the line something got misread here. His current head is a 706. I don't think ls1 heads where ever mentioned unless I missed something.
I believe what grey matter is refering to is that, with an Ls1 rotating assembly, the 243 heads raise compression from stock. The 706 heads he has from his 5.3 would then raise compression even higher if desired.
Personally I believe the 243 heads are the way to go. They give you a bump in compression (on a Ls1 rotating assembly) and have bigger valves and flow more than the 706 heads.
Old Nov 14, 2013 | 12:40 PM
69Camaro427's Avatar
the 706 valves are smaller also
706/862-1.89" intake 1.55" exhaust
243 - 2.00" intake and 1.55" exhaust
I think anything larger than a 5.3L needs a bigger intake valve, inorder to let those big bad boys breath. If you get an LQ9 and put 243s on it you have a LS2 besides the crapy intake manifold and cam would be 11:1 compression also. If you're running premium fuel I would say no higher than 11-11.5:1 compression for a dd
There is no replacement for displacement, except for boost and nitrous haha
Old Nov 14, 2013 | 12:42 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Agreed.
Old Nov 14, 2013 | 12:46 PM
Engine Size and Compression Calculator
This will get you in the ball park of compression range you want
Old Nov 19, 2013 | 07:48 PM
silveradojunkie13's Avatar
Thanks for the help, think ill just be better off with buying a ls2 or ls1
Old Nov 19, 2013 | 08:49 PM
gamble686's Avatar
LQ4/9 for the win! More power per dollar.
Old Nov 21, 2013 | 07:58 PM
Blackpanther99's Avatar
Old Nov 22, 2013 | 01:41 PM
I'm scared of aluminum blocks for longevity! Plus Lq4/9 can be found way cheaper and easier than most aluminum Ls1 or Ls2 blocks
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
old motorhead
Sep 29, 2015 08:22 PM
FormulaZR
Sep 14, 2015 05:23 PM
