Block Prep
Old Dec 19, 2007 | 11:35 PM
Banned
Default Block Prep
I Am Getting My Heads Worked On And I Was Wondering Wat Do I Need To Do To Clean The Engine Before Putting The Heads Back On Or Do I Just Put The New Gaskets On And Bolt Up The Heads
Old Dec 19, 2007 | 11:45 PM
moregrip's Avatar
what a rush!
maybe some scotchbrite, nothing that will take any material off.
definitely need to chase the threads and blow out the bolt holes
clean up the pistons
Old Dec 19, 2007 | 11:50 PM
TXsilverado's Avatar
an ice scraper for the big stuff, follow it with a razor blade and finish it up with a scotch brite pad soaked with brake cleaner.
blow out the threads with an air hose and chase it with a bolt with 2 sides of the threads ground flat.
Old Dec 19, 2007 | 11:51 PM
iamkeniff's Avatar
how do you clean off the pistons?
i'm doing a 6.0 rebuild too...
Thanks
Old Dec 19, 2007 | 11:55 PM
moregrip's Avatar
what a rush!
Thanks
this is what I did:
Old Dec 20, 2007 | 12:21 AM
iamkeniff's Avatar
MoreGrip, how'd you get down into the ones that wasn't at top of their stroke?
Old Dec 20, 2007 | 12:26 AM
turn the crank bolt until they are top dead center...
Old Dec 20, 2007 | 12:31 AM
iamkeniff's Avatar
that's what i thought. but i wasnt sure.
will it be easier to turn it without out the plugs in?
Old Dec 20, 2007 | 12:52 AM
if you can see the pistons, there are no spark plugs. you spark plugs thread into the heads. it will take a little muscle but the rotating assembly will turn with the crank bolt. just make sure and go clockwise. oh and cleaning the pistons as good as grippy did is kinda pointless. it makes for an awesome pic but within 5oo miles it will be back black again. just pour some seafoam on the piston and clean it up the best you can with a towel. thats good enough.
Old Dec 20, 2007 | 01:53 AM
Banned
this is wat im workin on 06 5.3
NEXT I AM TAKING OFF THE HEADS TO GET WORKED AND THE NEW CAM WILL GO IN SEE HOW IT GOES
calsdad
Jun 14, 2023 11:07 PM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
