best cam for nnbs 6.0 with l92 heads??
#42
the 07-10 6.0 is the exact same as far as i know. i wouldnt put too much thought into it other than does that **** have VVT and DOD??!? if so then get ready to sink a couple hundred in pulling that dod and vvt out.
just so you know there is a p/n list for the dod delete
#44
OTE=iamkeniff;5037980]Id have to see a log from a dig on DRs, and id have to see the tune to tell you. Thats plenty of cam to get that thing to 7.99 1/8th mile. Either its not enough timing out the hole or too much. KR out the hole or its got KR throughout the run. IATs are too high, something. If i can 8.0 1/8th mile in a 560bs truck then i know a rcsb can 1/8th mile better[/QUOTE]
Silverado1ss89 is at 12.8afr 28° timing shifting at 6500... I'll c if I can find his logs and send them to U..
I believe he has traction issues at the track he's only going 2.0 60' ...
#45
those heads can handle and move heat rather easy, throw some timing at her and let'r eat, just read the plugs, NA 12.8 is weak, go 13.5 i did it for years on my lq9 short block with alot more timing
#48
#49
very true, that's why reading the plugs to find out is so important you know nothing about the engine and what it likes or dislikes if the plugs aren't read, i listened to so many people on here until i was blue in the face until i learned how to read plugs, cant believe so much was left on the table. just saying!!
