Bad News
#44
i'm doin a cam/heads swap this weekend on my 4.8. The springs are already done on the heads so I just have to bolt them on. But what is this everyone is saying about the harmonic balancer? I am used to the older motors where we would just jam it with a breaker bar. What tool do I need to get the balancer off?
#45
Some guys rent the chrysler balancer puller from the parts place. You can impact the bolt out, you should replace it with a new bolt when it goes back together because it is torque to yield. Use a piece of all thread or the correct tool to pull the balancer back on. You want the all thread to be bottomed out in the crank before you start pulling the balancer on. Get the new bolt as tight as you can.
#48
14 Second Truck Club
I've done this twice and works great
#49
formerly lamborado (1-12-2012)
i used one of the cheap vato zone pullers and this is what happened
so dont be suprised when this happens, so i had to use a bigger one but apparently these results arent typical hahah as for putting it back on just heated it with a little 12$ torch from home depot and slid it on used the impact to put it all the way back on then hook a chain to it put the other end on a bolt somewhere on the motor and torque that bizatch down. lot easier than it sounds.
#50
I used the "wine bottle opener" style compressor when I did my cam swap. It did work but it was a big pain in the ***. I will be buying the proper tool before I tackle my next swap.
lukn4trbl355
10-21-2015 11:19 PM
