Is this a bad idea
Old Oct 3, 2010 | 03:11 AM
als777on's Avatar
Default Is this a bad idea
Trans/ shift kit and stall converter
Engine / 408 storker kit
X link and 90mm throttle body
pacesetter headers 02 sensor are still present but
catalytic converter are gone
Magna Charger 112 3.0 pully with 90mm jtube
volant cold air intake
Yella Terra rockers 1.7 RATIO
Comp cam part#54-477-11 Cam Spec
Intake Exhaust
RPM Range: 2200-7000 Valve Lash: Hyd. Hyd.
Valve Timing: 0.006 Duration: 277 293
Lobe-Center Angle: 114 Duration @ .050" Lift: 227 243
Intake Centerline: 109 Valve Lift: 0.614 0.624
Lobe Lift: 0.361 0.367
afr heads
225 cc runners
Combustion chamber 72cc
compression is 8.6-1 with arias pistons
Old Oct 3, 2010 | 03:13 AM
RandomHero's Avatar
Your transmission is going to last about a day with that setup.
Old Oct 3, 2010 | 05:10 AM
Gadgetized's Avatar
I agree with RandomHero. Get a 4l80e and be done with the tranny. Also the 112 is a nice supercharger, but has its limits. The 408 with a 3.0 pulley on a 112 is not going to benefit like it would with a bigger supercharger or a large turbo. I personally like a turbo much better than a supercharger.
Old Oct 3, 2010 | 09:13 AM
1Bear's Avatar
I believe with the little 112 on a motor as large as a 408, if you go ahead pulley all the way down as far as you can go, you will still only come in around 4#’s of boost and a fairly aggressive cam will only make things worse on the boost side of things. You may end up wanting to convert to an 8-rib set up with an over-driven crankshaft pulley. Even if you do find yourself able to upgrade superchargers down the road, you would still appreciate the higher capabilities that an 8-rib system will afford you, so it’s not like you will be pissing in the wind by upgrading it now. Never-the-less, as the other guy’s have said, you should still make good transmission ripping power, it just will never be to the potential of what your combination is capable of.
Old Oct 3, 2010 | 12:04 PM
als777on's Avatar
thank you all for your input as for the trans I do plan to upgrade I think for right now I am concerned about the compression being so low and what to do with it I do plan to go with a bigger supercharger think I would just want to know if I should bring the compression up or just leave it
Old Oct 3, 2010 | 07:51 PM
terravast4's Avatar
Leave the compression and put a 2300 on it.
Chavette
Oct 28, 2015 07:33 PM
Tydriver
45
Oct 23, 2015 09:19 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
TAPyvehc93
Sep 12, 2015 08:19 PM
