Bad Head Gaskets
Old Aug 15, 2009 | 12:33 AM
kybray44's Avatar
Registered User
Default Bad Head Gaskets
Just found out today that I have two bad head gaskets after pressure testing the cooling system. I was quoted roughly 1700 to repair, does this seem fair? Parts were 440. I was wondering if it would be better to swap or to do some upgrades while replacing the gaskets? Any input is appreciated. Thanks
Truck specs
01 Silverado 5.3 with 84k
Old Aug 15, 2009 | 12:41 AM
damn you could buy a set of ported heads and gaskets and cam for that price where are you located ?
Old Aug 15, 2009 | 12:45 AM
kybray44's Avatar
Registered User
Sacramento, CA
Old Aug 15, 2009 | 12:46 AM
kybray44's Avatar
Registered User
After checking out GMPartsdirect, it appears the gasket itself is only about $31 a piece. Does this sound right?
Old Aug 15, 2009 | 12:47 AM
kybray44's Avatar
Registered User
How much would I be looking if I wanted to do a 6.0 swap?
Old Aug 15, 2009 | 12:55 AM
A Low Dime's Avatar
13 Second Truck Club
Gaskets are $33 a piece, head bolts are $20, coolant and oil are less than $50.
Old Aug 15, 2009 | 12:59 AM
Spoolin's Avatar
GFYS and STFU
There are people on this board that will do that job for you for about $300 plus parts.
Old Aug 15, 2009 | 01:03 AM
your right spoolin. you could do an lq4 swap for that price.
Old Aug 15, 2009 | 01:09 AM
kybray44's Avatar
Registered User
wow, i figured they were jackin meee. How dificult of a job is it? Is there some place I could throw an ad up to get some help Spoolin?
Old Aug 15, 2009 | 01:11 AM
im sure someone local will get on here sometime soon and help you out it's not that difficult if you are a little mechanically inclined.
