assembling 408 stroker
Old Mar 25, 2015 | 07:22 AM
Tigger Welder's Avatar
Check those rod and main clearances, they seem scary loose!
After building a bunch of engines and having my Craftsman torque wrench fail several times and friends having similar experience, I bought a 3/8" and 1/2" Snap-On Torque wrenches, click type. That was in 1992. I have built 20+ engines since without a single issue. Not sure what they do now, but back then Sears would warranty a failed wrench for 6 months. Not helpful when it fails at 9:30 Saturday night when you are at the track trying to get an engine put together for the National Championship Runoffs Sunday at lunch! Thanks for a friends Snap-On to get it put together!
Mike
Old Apr 1, 2015 | 06:57 PM
brandon6.0's Avatar
yeah they are on the loose side but ls engines have a really nice oiling setup. besides boost is kinda hard on bearings so most guys go a lil looser on the clearance. research it!!
Old Apr 2, 2015 | 01:10 AM
Jake75's Avatar
I decided to go 24 and 26 for the rings. On another note I hate spirolox! My first time dealing with them...took me about 30 Mins to get one in. Also got a cut/raw finger in the process. After the first one I got 7 installed in about 15 mins!
Old Apr 2, 2015 | 03:26 PM
Not to beat a dead horse, but the books say to use 0.0022-0.0030 bearing clearance. This is 2.2 to 3 thousanths, not 25 to thirty. 25 to 30 would clank when you picked up the crank snout and without a 500 gpm oil pump, would have zero oil pressure.
Old Apr 5, 2015 | 12:34 PM
brandon6.0's Avatar
yeah he should already know that. forgot a zero but common sense u should know what I ment. thanks for the clarification.
Old Apr 7, 2015 | 01:07 AM
Jake75's Avatar
well I just finished checking main bearing clearance (plasti gauge) and I believe I'm right where I need to be! The crushed piece just about lines up with the .002 inch mark and is slightly bigger than the .003 inch ill post a pic tomorrow
Old Apr 7, 2015 | 10:58 AM
Jake75's Avatar
Old Apr 8, 2015 | 08:29 PM
Jake75's Avatar
I checked my rod bearing clearance today and it read .015 " I was told .025" was ideal. So now what would I do to achieve that if I'm getting .015" with standard size bearings? Or is .015 plasti Gauge reading acceptable? I'm hoping to make atleast 1000 hp thru a turbo
Old Apr 8, 2015 | 11:29 PM
Jake75's Avatar
CB663HXN i brought some of these they have a thinner wall allowing for .001" more clearance so that should put me where i need to be!
Old Apr 11, 2015 | 11:44 AM
brandon6.0's Avatar
yeah that should put u right in the ball park. it looks to me like around .025 on mains and rods. that should be perfect for what your trying to do. Good Luck!
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
blown02408
Oct 1, 2015 01:06 AM
sTNT971
Sep 26, 2015 04:22 PM
11MPG
Sep 10, 2015 08:34 PM
