ARP Studs
Old Jul 4, 2005 | 10:30 PM
TURBO8's Avatar
Default ARP Studs
I am about to put in these arp studs and was wondering is there a torque wrench designed for stucs? Or do you just tighten by hand as much as you can, and just torque the bolt? If so then to what spec?
Old Jul 4, 2005 | 11:53 PM
PappyDan's Avatar
Tribe Shaman
go to sears
Old Jul 5, 2005 | 01:49 AM
moregrip's Avatar
what a rush!
Not sure, some studs utulize a slight preload and some go finger tight.
In any case, you won't be torque-ing the studs, you will be torque-ing the nuts. The directions should tell you what the studs need. Also, make sure you blow out all the stud holes with compressed air and use the proper lube on the threads.
Old Jul 5, 2005 | 11:52 PM
TURBO8's Avatar
thanks
Old Jul 5, 2005 | 11:55 PM
TURBO8's Avatar
should I tap the holes as well? If so what size tap.
Old Jul 6, 2005 | 12:25 AM
BigPurp's Avatar
No don't "tap" the holes... you can use a thread chaser, but this is NOT a thread cutting tap. Looks similar but not the same.
As for the studs, screw them in finger tight, thats it.
Old Jul 16, 2005 | 12:40 AM
mwalls54's Avatar
Need More N2O Mod
Studs i have used you just torque them down like normal. the studs will stay in place.
Old Jul 23, 2005 | 09:11 AM
1SlowHoe's Avatar
Destroyer of Transmissions
I watched a guy working on my buddys vette snap an ARP stud because he read and followed the directions. The directions said not to use the factory tq values and to use the ones given with the kit. Well he did that and snapped one. He then called ARP and they neglected to put the value for the smaller studs in the directions, the directions were reading as if all the studs were the same tq value and of course they are not. If in doubt call them, should be a number in your kit.
Old Aug 6, 2005 | 04:30 PM
Hawk179's Avatar
I would be careful if I were you. You cant just stick studs on to a block that was not bored or honed without a TQ plate. This will distort the block and you might twist the cylinder.
Rick
SS94S10
Jan 3, 2019 01:57 PM
AdaMax
May 16, 2016 11:35 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
sTNT971
Sep 11, 2015 02:38 AM
