Anyone hear running 11.25:1 or higher on Pump Gas DD?
Old Dec 16, 2009 | 09:32 PM
Pontiac Derek's Avatar
Default Anyone hear running 11.25:1 or higher on Pump Gas DD?
anyone hear running 11.25:1 or higher on Pump Gas DD successfully? what cam? converter? intake? thanks
Old Dec 16, 2009 | 09:38 PM
dirt track racer 81's Avatar
I was with my ls6 heads milled. vic jr 244/248 .612/.615 112 lsa 4.56 3200 stall. i was around 11.7:1
Old Dec 16, 2009 | 10:35 PM
Thanks !My 383 stroker 5.3 block is just about done at the machine shop and i'm just about to order pistons, i went with a different cam than i planned, was 224-230 but found a nice Comp XER used-232-234 at 50 .600 lift 112lsa Hand Ported Dart 205cc heads, coated chambers/valves/ex ports, planned vert is a 3000-3200 Yank SC with 3.42 gears for now then when i can 4.10's will go in, I want to go with 11.5:1 with this engine so i'm just curious if anyone else is doing the same, thanks for the replies! Pistons will be either Top and side Coated Manley's or top and side Coated Wiseco's with offset pins and steel rings ect, My local fuel is 91-92 octane fwiw
Old Dec 17, 2009 | 01:15 AM
jophuss36's Avatar
11.65:1. But it's all about your dynamic compression ratio not so much stAtic
Old Dec 17, 2009 | 05:19 PM
acethedragon's Avatar
true. ls motors can handle higher cr than previous motors. just combine it with the proper cam to bleed off low end cylinder pressure which is where detonation tends to happen. up higher in the revs its less likely, but be sure your tune is spot on either way
Old Dec 17, 2009 | 08:36 PM
Yep, i understand, just wanted to see if any of you guys are, How do you like that cheater cam you have?
Old Dec 19, 2009 | 09:10 AM
budhayes3's Avatar
PT's Slowest Truck
A single pattern cam with a tight LSA and a lot of duration is good for higher SCA engines...
Old Dec 19, 2009 | 09:41 AM
Phantom's Avatar
11 Second Club
Around 11.5:1 here on 91 octane
Old Dec 19, 2009 | 06:33 PM
MPFD's Avatar
11 Second Truck Club
yeah, on the street but I don't really get on it much on the street. No use it has no hope of hooking, Maybe a ricer drift through a roundabout now and then just to impress the kids. But when I'm at the track I run VP with my spray...
Old Dec 20, 2009 | 11:58 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its not necessarily the low end where you'll get detonation, its most likely going to happen at peak torque.
My buddy closet red neck on here was running 12:1 in his head and cam 5.3. It was a tempermental bastard but ran like a scalded ape. I believe he still has the heads and cam laying in his garage if youre interested.
