Antiseize on Headstuds??
Old Nov 18, 2012 | 11:49 AM
Default Antiseize on Headstuds??
My local machine shop said I should put a little dab of antiseize on the threads into the block? I have read some use motor oil and most run them dry.These are ebay(procomp) studs going in my 5.3. How do you guys feel about this?
Old Nov 18, 2012 | 04:24 PM
Ferocity02's Avatar
I put my ARP studs into the block dry, then used moly lube on the threads and nut/washer surfaces when torquing.
Old Nov 18, 2012 | 05:40 PM
I dont think it would hurt since some have put motor oil on them. I want to be able to remove them if I toast this motor,yeah I know they were 65 bucks who gives a **** if you cant get them back out
Old Nov 18, 2012 | 10:44 PM
1dirtybird's Avatar
I always put arp lube on all my head bolts/studs going into the block. Just a habbit, and ive done alot of heads lol. You dont need alot just a swipe.
Old Nov 19, 2012 | 08:40 AM
TXsilverado's Avatar
i run OEM bolts dry and ARP bolts with moly lube. never had a problem.
Old Nov 19, 2012 | 11:07 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
We have never used the procomp studs, but the ARP sets we use will get the molylube.
Old Nov 19, 2012 | 04:56 PM
Cool thanks for the response guys.
Old Nov 19, 2012 | 07:55 PM
Onetogofast's Avatar
Always good with the lube
Old Nov 19, 2012 | 09:20 PM
silverz28camaro's Avatar
I was thinking of using those budget studs but became nervous after reading this after a seach....I am not calling them junk but ARP is proven, I would have liked to see a picture of this broken stud
https://ls1tech.com/forums/generatio...e-garbage.html
Old Nov 27, 2012 | 02:09 PM
Truck Sponsor
We have a few customers that are running those studs with our heads, however I haven't heard any good or bad info on them.
