Answer me this please
Old Nov 25, 2007 | 04:19 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Answer me this please
Can standard length pushrods be used with a set of .20 milled heads.
Thanks John
Old Nov 25, 2007 | 09:14 PM
Truckshop's Avatar
it may work but i would have a set of 7.35's just in case.i have standard length on mine and they are milled .040 with a tr220 cam. it will depend on the base circle of the cam you are using.
Old Nov 25, 2007 | 09:27 PM
Baltimore Whore
How could I go about finding it, it is in the engine, thebox is hmmmm I have not a clue, getting ready to put it in the truck here in a few weeks, thought I would check. Cam is comp 224/581 112 from TSP if that would help. I will call tomorrow, but would be nice to know tonite. Thanks
John
Old Nov 26, 2007 | 09:42 AM
Truckshop's Avatar
you will have to call them to find out the base circle. if it is a smaller base circle you may even need 7.45's. i checked with thunder racing when i bought my cam. but they are also local to me.
Old Nov 26, 2007 | 10:33 AM
TouchOfEvil04's Avatar
pushrod length checker.
Old Nov 26, 2007 | 10:41 AM
ap2002's Avatar
best way to find out,
but my friend milled his .030 on his LQ4 and used that same cam you have with 7.400, so you should be ok,
Old Nov 26, 2007 | 02:02 PM
TarheelZ's Avatar
Note that he's saying .20, not .020. BIG difference.
Old Nov 26, 2007 | 03:54 PM
Baltimore Whore
I talked to John at tsp today and he said it will be fine. My bad I screwed up it is .020 not .20
Thanks John
sTNT971
Sep 26, 2015 06:27 AM
The Sgt
Sep 24, 2015 08:06 AM
Tuckin15s
Sep 23, 2015 09:35 PM
zblee
Sep 17, 2015 07:58 AM
FormulaZR
Sep 14, 2015 05:23 PM
