another cam question. Need help with a cam for a 418
Old 03-12-2008, 11:48 AM
Dark Halo's Avatar
Default another cam question. Need help with a cam for a 418
I am running a 230/236 with a .591/601 110lsa in my 6.0 thats in my 02. The cam will be placed in the 6.0 for my 92 and the 02 will be getting a brand new 418. I will be using the same heads or I may buy a custom pair from the shop that is building the 418. Just wondering how much cam I should go with. It will be a N/A motor and maybe later on a little N20, but that is only if I can not reach my goal N/A. the truck is only driven on the road maybe 250 miles a month.
Old 03-12-2008, 12:53 PM
Hunt&Fisherator
silver-mod-o's Avatar
kind of off topic but who's assembling the motor??? what dimensions are you using to get those cubes? Are you aware of the oil consumption issues??
with your stall I wouldnt be scared of going in the low-mid 240's for duration and .630 on the lift. Keep your 110 LSA and advance it 2* IMO... should be a string *****
Old 03-12-2008, 02:15 PM
ZZebes's Avatar
Did Cody get a new S/N ????
Old 03-12-2008, 05:08 PM
Dark Halo's Avatar
same spec as the one on texas speed and performance. I am using the L92 LS3 block procell brothers custom engine builders in orange tx is doing the build. He told me he would match or beat any price I could find.
Old 03-12-2008, 05:11 PM
Dark Halo's Avatar
not sure I follow
Old 03-12-2008, 05:12 PM
ZZebes's Avatar
not sure I follow
NVM, it's not aimed at you, for another member that had oil consumption issues with the 418 combo because the stroke is just really long for a stock bore
Old 03-12-2008, 05:18 PM
Dark Halo's Avatar
with the L92 block it has a 4.080 bore with 6.125 rods and a 4 stroke crank sould not be bad. I will have to redo some wiring for the new cam and knock sensors but it will be built with the 24 tooth wheel on the crank.
Old 03-13-2008, 11:55 AM
Dark Halo's Avatar
what do you guys think about the Texas speed MS4 cam? Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation (111 LSA Standard)
Old 03-13-2008, 11:57 AM
Hunt&Fisherator
not a fan off anything off the shelf really to be honest... build your own tailor made cam for the same money and have it do exactly what you want...
Old 03-13-2008, 12:04 PM
Dark Halo's Avatar
only reason I ask I can get a used one prettty cheap.
Quick Reply: another cam question. Need help with a cam for a 418
