Another cam question
Old May 21, 2012 | 09:58 PM
BradS04's Avatar
Default Another cam question
Has any ran a Futral f6 in a 5.3 is so what did you think anxious to know if it was performer or not been considering this cam for awhile.
Old May 21, 2012 | 10:03 PM
ltr450ryder's Avatar
need more converter for that cam
Old Jun 12, 2012 | 09:57 PM
BradS04's Avatar
So no one has had any experience with this cam from from Futral?
Old Jun 13, 2012 | 12:25 PM
Sales1@Texas-speed's Avatar
FormerVendor
In my opinion that cam is a bit on the large side for a stock cube 5.3. Unless its primarily a track application and your planning on running a converter with a higher stall rating than a 3200.
Old Jun 13, 2012 | 02:30 PM
03sierraslt's Avatar
I would say that cam is a bit large also, what are your goals for this setup? What RPM do you hope to shift at? You could run that cam with more converter but I say it's still too big.
Old Jun 13, 2012 | 03:08 PM
FormerVendor
^Agreed even if he runs a higher stall converter hes going to have to spin that 5.3 pretty good to take advantage of that cam.
Old Jun 21, 2012 | 11:05 PM
BradS04's Avatar
Well you all may think I'm crazy but I don't really have any main goals it's not a dd its more of a toy I plan on taking it to the track off and on and street driving it occasionally I plan on running a 3600 converter and a 4:10 gear soon and probably a 125 shot I would be happy running a low 12 at the track tho I already have a tr220 it's jst not all that radical but don't get me wrong it runs great I jst want more without having to go FI I'm jst working with what I have for now!!! And I only spinning it 6200! With all that being said I was jst looking for a better cam than what I have now eventually it will have a built 408 but thats a while away!
Old Jun 22, 2012 | 06:58 PM
jrmchevyman's Avatar
If it will be mainly for track, you can get a good running 5.3L with the proper mods.
Go 9.5" 3800rpm - 4400rpm converter, tbss intake, built trans, 4:10 gears or possibly shorter gears, new heads to bump up the compression, bigger injectors and bigger Throttle Body and then the Futral F6 cam 226/230 cam would run like a raped ape. Another choice would be a EPS custom grind around a 227/230 or 226/230 with a little more lift than the Futral F6.
If you don't want to spend all the money on all the supporting mods to make it run properly, then I agree with the others, stick with the cam you already have or go smaller than the Futral.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
