Another Cam Q
Old Mar 4, 2009 | 08:23 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by snwmn984
Oh boy...
Synergy, hopefully i can get a custom grind from comp, if they are still around.
Comp's still around...they own quite a bit actually, I just recently heard that they also own Lunati. Crane's gone now...I'm still wondering who's grinding Vinci's cams now...
Old Mar 4, 2009 | 08:30 PM
  #22
sonoma43's Avatar
one's gotta think that vinci will turn to Comp to grind thier cams now
Old Mar 4, 2009 | 08:50 PM
  #23
stock48's Avatar
9 Second Truck Club
Dang, isky's site is down.
They are all custom grind's PM me for info.
Originally Posted by sonoma43
Will be a rougher idle with those lsa's for a towing application. that 206/212 looks good, I would like to see it on a 114 though.
How aggressive are the ISKY lobes? are they comparitive at all the Comp XE-R's?
The smaller duration less than 222@.050'' are a little milder, but the mid to low 220's up are about the same as the XE-R. The comp lobes have a little more duration @.200''(lobe) but the ISKY's have a little more at .300''(lobe lift) I have the 215/215, .566''/.566'' , 114* in my truck right now and idle is fairly smooth. Has a light lope cold but fades out when hot. The .532'' isky lobes are narrower seat to seat so thay will idle smoother. For towing the 110, and 112 lobe center work well because the torque is in the midrange. The wider center is a little stronger right off idle, and past peak but weeker in the midrange.
Old Mar 4, 2009 | 09:48 PM
  #24
snwmn984's Avatar
Now i'm confused on what to get?!
Old Mar 5, 2009 | 12:20 AM
  #25
SynergyV8's Avatar
Oh boy...
Lingenfelter and Texas Speed can grind Comp lobes...or do they still send in orders from customers to Comp? I can't remember anymore, but if you call either one of those companies and ask for a custom grind knowing 98% what you already want, they can help.
Old Mar 5, 2009 | 12:29 AM
  #26
SynergyV8's Avatar
Here this may help a bit.
http://www.compcams.com/Technical/FAQ/LSAproperties.asp
Old Mar 5, 2009 | 01:23 AM
  #27
99Silverado5.3's Avatar
Originally Posted by white lightning SS
The specs of that Vinci cam look good for what your asking IMO.
+1 for the vinci.
Old Mar 5, 2009 | 02:14 AM
  #28
stock48's Avatar
9 Second Truck Club
Originally Posted by SynergyV8
If you look at where the stock 5.3L cam specs fall on the tach, the 190/191 duration camshaft starts to peter out around 4800-5000. The 196/207 6.0L cam starts to run out of breath about the same time but with 39 more cubic inches. This gives us a little something to work with when we factor in the displacement of the 5.3L. The 6.0L cam in a 5.3L would raise the rpm band of the 5.3L a few hundred rpm's to about 5500 or so. That's not that big of a change, especially when comparing camshafts still under .500" of lift. With small duration cams, you want the extra lift and valve timing to enhance the cylinder pressure within the given RPM range you're trying to boost up. Cylinder pressure makes torque, and torque makes fun.
So, where to next? Now is when you start looking at other members on here who have installed a similar cam into the same displacement motor as you have with the mind frame that a 196/207 cam will bring a 5.3L up roughly 500 rpms from stock. Check out their videos and see where the tach starts to fluff off, if any, during the RPM range you're interested in. For this towing/daily driver/fun at times truck, an idle-6100 RPM range is plenty. Make the same variable degree duration jump we made from the 5.3 to 6.0 cam and you have a 20x/21x duration cam with roughly an additional 500 RPM's of room on the tach.
Good Information!
Old Mar 5, 2009 | 04:22 AM
  #29
sonoma43's Avatar
I know that Texas Speed sends in their order's to comp and then comp grinds them. Not sure about lingenfelter but they probably do the same thing
Old Mar 5, 2009 | 08:30 AM
  #30
white lightning SS's Avatar
I still say stay with the 115+ LSA to ease with tuning and driveability.
