another cam noob.
Old Jul 15, 2013 | 08:37 PM
Ricksilvy's Avatar
Default another cam noob.
Looking to improve my low to mid range power. Must pass smog cause California sucks *****. It's a daily driver and plan on upgrading Trans to 4L65E with a stall(one that's streetable). I still tow with it as well.
Someone has a custom grind 208/208 .5xx .5xx 112lsa that might be up for grabs.
What you guys think??
Oh, mods are below.
Old Jul 16, 2013 | 09:34 AM
Vortec350ss's Avatar
Unfortunately a cam isn't the way to go for low end grunt... there isn't much you can do with that 4.8 outside of forced induction to help that.
Old Jul 16, 2013 | 01:18 PM
Ricksilvy's Avatar
Yeah I know the lil 4.8 lacks bottom end torque. The gear swap helped a lot.
Well what i'm trying to do is wake up the motor a bit and not lose any bottom end.
Would like a healthy running street truck with nice power across the power curve.
Old Jul 16, 2013 | 02:20 PM
Richardman1992's Avatar
I've got a comp 212/218 low lift in my truck and while I haven't smogged it yet, I have no doubt it will pass.
Old Jul 16, 2013 | 03:59 PM
craigsix's Avatar
try a 2600 stall and an underdrive pulley. i run 1.8 yella terra ultralites that make a nice difference with stock cam.
Old Jul 16, 2013 | 05:33 PM
Ricksilvy's Avatar
Any opinions on the custom grind cam listed above?
Old Jul 16, 2013 | 07:39 PM
Whitecrewcab's Avatar
That cam will be close on getting it to pass emissions. The 4.8's are so little that it does not take much cam overlap to cause idle difficulties.
Old Jul 16, 2013 | 08:09 PM
Ricksilvy's Avatar
was told by seller that it will pass smog. Defiantly need pass emissions
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
