Adjustable Timing chain?
Old Aug 16, 2008 | 10:39 PM
SLO TRUCK's Avatar
Default Adjustable Timing chain?
I am going to do a cam swap with a turbo in the future. My question is an adjustable timing chain a worth while investment for a few more degrees of timing. Looking to get all my ducks in a row for the cam swap. I will be putting on Underdrive pulley and new valve springs also. Any thing else yall can think of.
Old Aug 17, 2008 | 12:50 AM
artypyro's Avatar
12 Second Club
not sure if adj. timg chain is worth the money unless you want to pull water pump ect. to retard/advance cam timing. don't think it gives any more horses just moves the power band either up or down somewhat, if the cam is properly sized to the motor that is. you mentioned pulley and springs, id get pushrods also
Old Aug 17, 2008 | 12:57 AM
Mangled03gmc's Avatar
Baltimore Whore
I wouldn't go for it, at least not for the price. Just advance the cam when you put it in.. Thats my op. +1 on the PR's
John
Derek @ EDO's Avatar
FormerVendor
The adjustable timing sets on the LS-based motors are used to degree in a cam.
Most cams are off by a couple degrees. There was a thread where a guy installed a cam with the factory gear set, he felt as if he would benefit from degreeing the cam in so decided to purchase an adjustable timing set. He saw where the cam was off by a few degrees so he corrected it with the adj. timing set.
His results didnt show much improvement.
Derek
Old Aug 17, 2008 | 01:08 AM
SincalT/A's Avatar
If your going turbo later save your money now and go none adjustable.
Old Aug 17, 2008 | 01:28 AM
SLO TRUCK's Avatar
thanks guys
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
chevyl33
Aug 24, 2015 08:21 AM
Boombastic
Aug 5, 2015 11:38 AM
Ammadien
Jul 22, 2015 08:50 PM
