370 5.3
Old Aug 15, 2008 | 04:27 PM
UBLUZIN03's Avatar
Default 370 5.3
Can a 5.3 be made into a 370? Can i use the 6.0 crank? How much would the bore have to be?
Old Aug 15, 2008 | 04:45 PM
454SuperSport's Avatar
no, 5.3 and 6.0 have the same stroke and a 5.3 block cannot be bored to 4.03"
Old Aug 15, 2008 | 04:46 PM
kbracing96's Avatar
No, you can't bore a 5.3 block that far. 5.7 is the most you can bore a 5.3 block. 6L crank is the same as a 5.3.
Old Aug 15, 2008 | 04:51 PM
UBLUZIN03's Avatar
Damn i found a 5.3 for sale cheep....o well i guess ill keep looking for a 6.0...
Old Aug 15, 2008 | 05:52 PM
dirt track racer 81's Avatar
you can make a 383 with a 5.3
Old Aug 15, 2008 | 06:57 PM
sharpshooter's Avatar
I have a 5.3[108k miles] short block that lost compression on cylinder #7 from boosting.The cylinder and top of piston still look fine.It must be a ring land.I haven't opened the bottom end of the motor.It was pulled this past spring.You can have it for FREE if you come get it.It has been stored in my garage.Then you can try anything you want without the initial cost of the motor.
Old Aug 16, 2008 | 01:03 PM
UBLUZIN03's Avatar
were at in delaware?
Old Aug 16, 2008 | 03:14 PM
Milford,Delaware
Old Aug 16, 2008 | 04:29 PM
UBLUZIN03's Avatar
Pm sent
Old Aug 19, 2008 | 01:05 AM
53bowtie's Avatar
bore it out to 5.7 spec pistons and throw a 4" stroke crank and you could have yourself a 383 > 370 (in cu. inches anyway).
