? about the 05 5.3L
Old Mar 21, 2007 | 03:43 PM
mean05's Avatar
Default ? about the 05 5.3L
is there anything different about these motors over an older model one, the one i got was factory rated at 315hp, does it have higher compression different heads, where do they get the extra 20hp from, i am curious?
Old Mar 21, 2007 | 03:52 PM
Barras's Avatar
Is it the aluminum blcok model 5.3? They make higher HP numbers than the iron blocks altho i do not know what all if different about them.
Old Mar 21, 2007 | 04:28 PM
TURBHOE's Avatar
heads and cam i think.
Old Mar 21, 2007 | 05:15 PM
Cuerva's Avatar
11 Second Truck Club
There have been several upgrades over the years in models. Cam on 99-00's are different, there's two different sets of heads but I don't think that made a difference. 99-00's trucks have different pcms which make some difference. 05's and up trucks come with E-Fans which also free up a few ponies.
The new 07 5.3's motors have different heads and I think bigger throttle body.
There's other stuff I can't think of right now.
Old Mar 21, 2007 | 05:37 PM
Moddoo's Avatar
L33 did not come in a reg cab
Old Mar 21, 2007 | 09:43 PM
TarheelZ's Avatar
My brother knows whereof he speaks.
Old Mar 21, 2007 | 09:45 PM
Bo185's Avatar
I heard over on tech and on gm powertrain site http://media.gm.com/us/powertrain/en...RTEC53LGENIVV8
that the 07 up 4.8/5.3 still use the Gen III based heads and intake not the L92 style yet but have the Gen IV blocks for the AFM.
Because the L92 heads will not fit the smaller bore blocks. I have heard that they are working on L92 small bore based heads, so should make more power there if they go with the l92 style heads on the small bore motors.
Old Mar 22, 2007 | 09:09 AM
nighthawk08's Avatar
from gm:
In 2005, Powertrain introduced a high-output Vortec 5.3L V8 (L33) for extended-cab full-size pickups. The L33 applied technology developed for the LS1 and LS6 Corvette V8s, with an aluminum engine block, higher-flow cylinder heads and a high-lift cam. It delivered more horsepower for customers who need it, without requiring a step up to the Vortec 6000 (and an increase in operational costs).
Old Mar 22, 2007 | 12:02 PM
mean05's Avatar
but my truck is a regular cab, and i am pretty sure it's an iron block, but we are pulling heads tomorrow to replace the lifters so i will find out for sure
Old Mar 22, 2007 | 07:45 PM
Bo185's Avatar
Just look at the block! If it's painted black it's iron, if is alumium in color than it's aluminum. Easy enough!
