9,000rpm oem rotating assembly, how would you do it?
Old Mar 21, 2012 | 04:02 PM
LowSilver's Avatar
I'm thinking you will need to go to a solid lifter for that kind of RPM no? 9000rpm seems like a TON of rpm for a cast crank I would think. Same with the stock rod. I know they are pretty good OEM pieces, but 9000rpm? Not sure on that one. That being said, I'm an LS Newbie as my signature states.
I have run up to 8000rpm with my car, but that's a Callies crank, H Beam steel rod, and a lighter forged piston. However, the stroke is 4.250" in my small block in the car, so at 8000rpm it's seeing a fair amount of swing action!
-Kenny
01silvy's Avatar
id love to see this.. I have faith you can do it but i dont think it will be "budget".. how would de-stroking the engine and increasing bore size workout at his kinda rpm?? just an idea.. Also id have it balanced, and then balanced again LOL
Old Mar 21, 2012 | 04:07 PM
CAGRacing's Avatar
Guys. I'm only hoping for 15,000 moles from this combo
Making it to the first regular interval oil change would be impressive to me.
I just wanna know what'll stop it dead in the water like the ECM not reading past 8,000. Obviously all my accessories will be removed, electric water pump, underdrive the alternator.
Old Mar 21, 2012 | 04:09 PM
rgvsierra's Avatar
Originally Posted by TXSZ66AVLANCHE
I can't offer any advice, but would like to see a video of a 9K rpm LS series...
heres a video and post for you.
SAM 433ci LSX breaks 1000HP N/A - LS1TECH
CAGRacing's Avatar
Do hydraulic lifters pump up or empty at highish rpm?
Old Mar 21, 2012 | 04:21 PM
jrmchevyman's Avatar
I have herd about an LS1 302 being talked about before and it would probably rev to the moon and be expensive to do.
I would rather go bigger cubes though IMO.
If you take "budget" out of the equation, then have someone build you a high revving engine if you want. It would be badass none the less, but costly.
Old Mar 21, 2012 | 04:27 PM
chevybowtie's Avatar
Big bore 4.00", small stroke with twin turbos.....Would be crazy.
Old Mar 21, 2012 | 04:28 PM
smokeshow's Avatar
Mod with training wheels
Just wait for the copo 327 engine...spin that OEM as high as you want Course it wouldn't be a budget build then...
Old Mar 21, 2012 | 04:50 PM
Lucille's Avatar
Dyno pulls that START at 7500 rpm
Old Mar 21, 2012 | 05:31 PM
mcfarlnd's Avatar
Un-Registered User
Originally Posted by CAGRacing
Guys. I'm only hoping for 15,000 moles from this combo.......
This made me think of austin powers goldmember lol!
I haven't seen a factory rotating assy. spin that high. I think it would be cool to see it happen and I wouldn't put it past these motors to safely achieve it. I remember the days when people thought 15+lbs of boost wasn't achievable on a stock bottom end.... just takes one person to have the ***** to try it. I would use the best bearings and bolts money can buy, be extremely precise on all clearances, definitely do something about the rockers and obviously balance the rotating assy along with flywheel/flexplate, clutch etc. etc. (not sure if you are going auto or standard) I imagine the oil pump would spin that high without throwing itself apart
