862 heads to 243
Old Apr 23, 2013 | 03:44 PM
99s10sbc's Avatar
Default 862 heads to 243
Would it be worht swapping to 243 heads from 862s on a 5.3 i will have them milled and put them on when i do my cam swap. Cam will be a 228R i will already be pulling heads since i am replacing lifters.
Old Apr 23, 2013 | 04:06 PM
Funkster's Avatar
12 Second Club
Yes it will be worth it in my opinion. Assuming you get them decently cheap. The 243 casting flows a good deal more air.
Old Apr 23, 2013 | 04:36 PM
99s10sbc's Avatar
150 for low mileage heads
Old Apr 23, 2013 | 05:47 PM
99s10sbc's Avatar
How much could I mill the heads without messing with the intake or running into piston to valve clearance?
Old Apr 23, 2013 | 10:15 PM
grey matter 04's Avatar
13 Second Truck Club
I wouldn't go anymore than .050 mill
Mine are currently milled .040
Old Apr 23, 2013 | 10:23 PM
ForcedTQ's Avatar
Exclamation
Fully depends on what cam you're running (sorry, haven't seen a CamPro graph of that 228R). But seriously, most recommend milling stock heads no more than .030". If you want to modify static compression more than that, you're better off getting the correct piston that gets you to the static compression you want.
Old Apr 24, 2013 | 08:39 AM
99s10sbc's Avatar
Not looking for anything crazy compression wise just figured i would mill them while i could. I got a good deal on the cam and was just putting it in till my motor is built so not interested in swapping pistons or fly cutting them this is just a budget type deal.
Old Apr 24, 2013 | 10:28 AM
Fastcount03's Avatar
I would mill them .030" with a .042 gasket and call it a day. It will definitely be worth your money.
Old Apr 24, 2013 | 10:51 AM
99s10sbc's Avatar
Sounds good thanks for the input
Old Apr 24, 2013 | 08:38 PM
99s10sbc's Avatar
Well 243 heads fell threw would the 862 heads be worth milling since they will be off anyway?
